Shim guidelines for Rovertym trailing links? - Defender Source
Old September 6th, 2011, 06:53 PM
seriousactualist
Paul Martin
1995 D90 ST
I'll talk to Rovertym in the morning, but does anyone know if they (RTE) have any guidelines for stacking their shims, according to the application (e.g., amount of lift)?
I'm pretty happy with the behavior with the stockers, so my initial thought would be to maintain the effective length of the stock links (hence current pinion angle), so far as possible.
In any event, it would be nice to have a good starting point....
-- Paul
Old September 6th, 2011, 07:11 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
How much lift do you have and are you running a stock driveshaft? That will determine how much shim you need do to pinion angles and the other components being able to deal with the new angles.
Old September 6th, 2011, 07:28 PM
seriousactualist
Paul Martin
1995 D90 ST
Right. The lift is ~2" lift with a stock shaft.
Old September 6th, 2011, 07:40 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
you need to measure the pinion angle and the output on the tcase.... shim accordingly to within 1.5 degrees
Old September 7th, 2011, 05:02 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
With only a 2in lift and a stock shaft...I wouldn't use any shims. Maybe the thinest one since that stock shaft won't put up with much of an angle. If you get DC shaft then you can use whatever you want to get the pinion angle back down so you don't have oiling issues.
Old September 8th, 2011, 07:24 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
What he said ^^^^
Old September 9th, 2011, 11:20 AM
seriousactualist
Paul Martin
1995 D90 ST
Bingo. No shims seems perfect here, since I just wanted to keep the same (effective) length as the stock links.
But with a CV at the output end, wouldn't the proper geometry be to point the pinion at the output (instead of having the centerlines of both in parallel)?
Thanks!
------ Follow up post added September 9th, 2011 08:20 AM ------
Thanks all!
-- Paul
Old September 9th, 2011, 11:45 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I have a 2 inch lift and RTE trailing arm's on a 97. I bought mine when Steve owned the company and we installed them at his shop using all three shims. To keep the vibes within reason I needed all three shims and DC shafts front and rear but that may just be my truck. What I don't like is the shims short your wheel base.
Old September 11th, 2011, 11:34 PM
cbass's Avatar
cbass
Bradlee Duncan
Yes, the shims can shorten your wheelbase, especially if you have a DC shaft. I'm using a an a-arm extension to get that wheelbase back while still leaving the pinion pointed up for the proper DC shaft geometry: http://www.rovertym.com/products?pag...category_id=56
rear trailing links cneal Defender Technical Discussions 11 December 11th, 2008 11:29 AM
Trailing links, side steps, rear bumpers/steps cbass For Sale - Parts 3 December 6th, 2007 08:39 PM
Equipe4x4 Rear Trailing Links UpnOver For Sale - Parts 3 November 4th, 2006 10:27 AM
Rockware trailing links, backlash artm Defender Technical Discussions 1 June 14th, 2005 03:59 PM
New Links section chrisvonc Community News & Announcements 1 February 4th, 2005 08:28 AM
