Shifting much better when cold. - Defender Source
Old November 23rd, 2014, 11:00 AM
richord
Richard Ordowich
1987/D90
I noticed that when I first start up my truck when is it cold, below 40F, shifting into second gear an higher gears is effortless. Once the truck heats up this effortless shifting goes away. I imagine it has to do with the oil being cold.
If that's the case, is there something I could do, like put in a different oil to make it shift this way even once heated up?
"Slow down and smell the diesel"
Old November 23rd, 2014, 11:15 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Is the oil/tranny fluid level correct?
Old November 23rd, 2014, 11:56 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Doesnt Lucas make some oil thickener or something? You know that display with the gears and the crank handle that sits on your autoparts store counter. "Regular oil" vs "sticky oil"
not that I advocate putting that stuff in my gearbox, but who knows. There are also MTF specific additives.
Old November 23rd, 2014, 01:15 PM
Run MTF. I use redline MTL. If you are running straight ATF they shift fine cold, but are crap when hot. MTL the first few shifts when cold you need to take your time, but it saves the synchros. Also, shift slow. The LT77 and R380 are notorious for wearing out synchros from shifting like a car.
Lucas is great for worn LT230s, but not rover 5 speeds.
Jumpseats removed, much better! shawnpalmer Misc. Chit-Chat 1 February 9th, 2008 03:07 PM
Sagging Suspension: How Much is Too Much? aclarke Defender Technical Discussions 9 June 19th, 2007 04:41 PM
Problems shifting out of 1st when cold chalkcreek Defender Technical Discussions 2 July 14th, 2006 10:56 PM
ZF Transmission Hesitation Shifting 1of40 Defender Technical Discussions 1 July 26th, 2005 11:41 AM
Shuddering when shifting... mlw911 Defender Technical Discussions 1 August 26th, 2004 09:18 AM
