Shifting Crunch - Defender Source
Old June 9th, 2007, 06:21 PM
mikeybob2@msn.com's Avatar
mikeybob2@msn.com
Michael Sabanovich
1994 Defender 90 #1880
Shifting Crunch
I just saw a 94 d90 for sale in the "for sale" forum and one of the faults with the truck was that the tranny crunches when shifting from first to second. Mine has done this since 1998 (when my warranty expired) so I am wondering if this is a common occurance? The mechanic at that time told me to just start in second until i need to replace the transmission for 4 grand..
So far I've been ok starting in second but not sure if I'm damaging anything... Any advice?
Old June 9th, 2007, 06:47 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Question
What oil are you using in the transmission ?
- Charles Eames
Old June 9th, 2007, 06:58 PM
mikeybob2@msn.com
Michael Sabanovich
Dextron III
Old June 9th, 2007, 07:18 PM
My 94 does that occasionally and I have the r380 installed. It only happens when I shift too quickly, so I just take it easy most of the time. I figure worst case scenario the synchro will blow and then I'll have to double clutch into second. A new trans isnt 4 grand, and while a hassle to replace, it isnt hard. Maybe RobD will weigh in with some advice that is actually informed by knowledge and experience, unlike mine!
Old June 10th, 2007, 12:10 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Thanks Jim!
I'd switch to a quality manual transmission fluid such as Redline MTL, MTF94, Royal Purple Synchromax, or Amsoil and see if that solves the problem. If it doesn't, your synchros are probably substantially worn, in which case an overhaul is in order. $4K for just a transmission replacement is a bit much. Heck, for four kilodollars I'll rebuild both your transmission and your t-case, fit a new (Genuine) clutch, fix the rear main seal leak, and buy you lunch at a nice Mexican restaurant when you pick it up. You can PM or call me if you need more info.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old June 10th, 2007, 08:24 AM
Andrew Vick
Andrew Vick
95 D90
Hell, I'll drive over the hill for that one! How far are you from Red River? (Rob)
Old June 10th, 2007, 08:31 AM
mikeybob2@msn.com
Michael Sabanovich
Originally Posted by Roadsiderob
I'd switch to a quality manual transmission fluid such as Redline MTL, MTF94, Royal Purple Synchromax, or Amsoil and see if that solves the problem........$4K for just a transmission replacement is a bit much. Heck, for four kilodollars I'll rebuild both your transmission and your t-case, fit a new (Genuine) clutch, fix the rear main seal leak, and buy you lunch at a nice Mexican restaurant when you pick it up.
Thanks Rob.. I'm going to upgrade the MTF per your suggestions. I'll let you know the results..
It's so ironic the the quote I got for $4k was from Land Rover Albuquerque on Alameda.. I lived in Corrales and used to take it there for service before I got transfered to Texas in 2002.. :-(
Where is your shop in Albuquerque?
Old June 15th, 2007, 11:54 AM
Roadsiderob
Robert Dassler
1994 D90
Michael,
My shop is about 6 blocks from the dealer. I was still in Colorado in 2002, though.
Andrew,
I'm guessing Red River is 3-4 hours from Albuquerque.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old June 15th, 2007, 02:15 PM
D90DRC
D Cantrell
1997 D90SW
Thanks Jim!
Where at "Sadies"
Old June 15th, 2007, 07:19 PM
Roadsiderob
Robert Dassler
1994 D90
Haven't been to Sadies...was thinking of El Pinto.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old June 15th, 2007, 07:56 PM
D90DRC
D Cantrell
1997 D90SW
Haven't been to Sadie's...was thinking of El Pinto.
My family owns Sadie's, give it a try... I grew up around that HOT food, It cracks me up at what pases for South Western food here in New England
Old June 15th, 2007, 08:53 PM
x10000000 on the Redline MTL its good shit, put some in your gear box and let us know what you think..
Problems shifting out of 1st when cold chalkcreek Defender Technical Discussions 2 July 14th, 2006 10:56 PM
Crunch bterpstra Defender Technical Discussions 6 March 21st, 2006 02:35 PM
94 shifting problems jstrong98 Defender Technical Discussions 6 January 26th, 2006 03:06 PM
ZF Transmission Hesitation Shifting 1of40 Defender Technical Discussions 1 July 26th, 2005 11:41 AM
Shuddering when shifting... mlw911 Defender Technical Discussions 1 August 26th, 2004 09:18 AM
