Shift Indicator Bulb...Where to buy? - Defender Source
Old November 9th, 2009, 05:45 PM
KKilo23's Avatar
KKilo23
Kenny
Where can I buy, need two. I pulled the old ones out I think they are 12V.
Part number is RTC6089...
Yes DAP has them and I think RN, but I am cheap and not paying 4+ a bulb unless they can't be obtained anywhere else....
Old November 9th, 2009, 06:26 PM
IIRC they are the peanut bulbs and available from an autoparts store. I know this because I, get this, use the shift ilumination harnesses to fix the side light harnesses.
Old November 9th, 2009, 06:27 PM
KKilo23's Avatar
KKilo23
Kenny
Thanks Ron. These bulbs aren't the same as the side light bulbs?
Old November 9th, 2009, 08:22 PM
are you talking about the ones on either side of the shifter? You can get them from any auto parts store. Disco's have them too. They are also the same as the hella city light on the 4000's and the headlights.
You just have to pick the wattage that you want. Go with the lowest you can find. If you need me too, I can take a picture. email me at swold at pbcx dot com
Old November 9th, 2009, 08:25 PM
KKilo23's Avatar
KKilo23
Kenny
Scott, thanks! I have already taken them out, I will just take the old bulbs down to the autoparts store and see if I can match them up.
Old November 10th, 2009, 05:10 PM
KKilo23's Avatar
KKilo23
Kenny
Advanced auto had them 2 for 3.49.
Old November 11th, 2009, 05:13 PM
Bill B
Bill
73 S3 109 Tdi, 95 RRC
Make sure you get the exact wattage as the originals. The Autozone ones I found that fit will melt your shifter plastic. The original LR ones are a lot lower watttage.
Bill B
Old November 11th, 2009, 05:15 PM
KKilo23's Avatar
KKilo23
Kenny
Bill B
Bill, thanks for the heads up. Do you remember what wattage you used?
Old November 11th, 2009, 06:37 PM
GYM's Avatar
GYM
Gary
97 SW
IIRC, doesn't the Owners Manual have a chart with the wattage of all the various bulbs?
Old November 14th, 2009, 01:12 PM
Bill B
Bill
I went with Genuine LR from AB in the end. It was cheaper than a new surround.
Bill
Old November 14th, 2009, 01:25 PM
KKilo23's Avatar
KKilo23
Kenny
Bill
Thanks, I know AB doesn't carry them anymore. But I agree with you a couple dollars spent is indeed cheaper!
Old November 14th, 2009, 11:18 PM
Bill B
Bill
Try Rovers North they might have some. If not then Pacific British. PB are really good to deal with. I got a lot of my RRC stuff from them.
Bill
Old November 15th, 2009, 09:28 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
#194 is the most common bulb of this type, and probably what came out of it- however if you were to use a #168 or #161 (both physically identical to #194) then you could run into problems melting the plastic as the lower the number, the hotter the filament
Old November 15th, 2009, 11:24 AM
wattage should printed on the bulb too.
Tell me why I should/should not buy a D90 fustogrande Defender Technical Discussions 44 March 2nd, 2006 11:57 AM
standard shift vs. automatic cobb Misc. Chit-Chat 15 May 10th, 2005 04:08 PM
GROUP BUY - HD Seat Covers from UK, All Models... RedRhinoProducts The Vendors Loft 0 December 10th, 2004 10:48 AM
Group Buy: Gas Tank Skid Plates SlickRockFab The Vendors Loft 53 September 20th, 2004 10:13 PM
difficult to shift my 94... JRowe Defender Technical Discussions 8 January 26th, 2004 01:21 PM
