Sheared bolt size - Defender Source
Old November 28th, 2015, 03:23 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Sheared bolt size
Just sheared the head off the tie bar and cross rod mounting bracket. Does anyone know what size / grade bolt this is supposed to be?
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
1971 109 3 Door (Sold)
Old November 28th, 2015, 03:41 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
And... Big hammer and punch technique is not working to punch it out. Do I need to unbolt the entire thing to make it easier?
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old November 28th, 2015, 03:49 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Ooof....have you tried a bolt remover on your drill?
Attributed to Shayne...
Old November 28th, 2015, 03:55 PM
the rover shop
shayne young
Pull the other bolts out and remove that bracket....it will either come off with that bracket or stay in the frame..if it stays you have a good inch or so to heat with a torch and get vice grips onto..if it stays on the bracket then it's a piece of cake to work on it on the ground or vice.. You're gonna wanna replace both bolts anyway while you're there..
Old November 28th, 2015, 04:05 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Do you happen to know what size bolts? I didn't see it in my manual.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old November 28th, 2015, 04:17 PM
the rover shop
shayne young
I will pull it up for you right now..
Old November 28th, 2015, 04:23 PM
the rover shop
shayne young
Here is a pic from microcat
Old November 28th, 2015, 04:26 PM
the rover shop
shayne young
Shows sizes as being 1/2" UNF by 6&1/2 or 6&1/4
Old November 28th, 2015, 04:28 PM
the rover shop
shayne young
But for all intents and purposes its a 1/2" UNF bolt.. Measure how long yours are and go by that as I'm showing a couple of different lengths..
Old November 28th, 2015, 04:33 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
I took it off... Applied heat. This biotch is frozen. Almost looks like one piece. Truly appreciate the help. Click image for larger version
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old November 28th, 2015, 04:39 PM
the rover shop
shayne young
Try not to wail on it from the other side too much..you may mushroom the bolt and make it harder to get out... Lay in on the ground and give the long side of the bolt a couple of whacks to free it, once it's moving push from the broken side...
Old November 28th, 2015, 04:44 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Sledge hammer will not even budge it.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old November 28th, 2015, 04:47 PM
the rover shop
shayne young
Then you haven't put enough heat into it...lol.. If time is on your side since the broken side is below the surface you can just sit it on a bench and fill the cavity side with penetrating oil and let it sit...it should creep down into the rusted section..may have to fill it a couple of times...
Old November 28th, 2015, 04:49 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Heat bolt till it nearly glows - let it cool a bit and use a stud wrench or pipe wrench to grab the bolt.
Arm in a vise and get it to rotate first, then work it out from there.
Email if you want phone number and I can walk you through a few more options to help.
Brian@defendersnw.com
Old November 28th, 2015, 04:53 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Have a shop press it out.
Old November 28th, 2015, 05:02 PM
Whoa Bobby - what project were you working on before you got sidetracked with this?
Old November 28th, 2015, 05:05 PM
the rover shop
shayne young
I'm gonna guess mounting a front skid plate..
Old November 28th, 2015, 05:17 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Looking for one open Sunday. My 110 is my DD and I need to get into work.
------ Follow up post added November 28th, 2015 05:19 PM ------
I was mounting a puma steering protection bar.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old November 28th, 2015, 05:31 PM
the rover shop
shayne young
If you can't find one..any shop with an air hammer should be able to move it...it's the quick succession of pulses that get it going and keep it moving..especially if you've soaked it and heated it and repeated..in prep for them to impact it out..
Old November 28th, 2015, 05:56 PM
Contractor's Avatar
Contractor
Will
1969 IIA
I'd try sticking the bolt in the vise and then heating it up, but you are going to need O/A type heat (mapp might work). Go find a 4' long piece of pipe that has an inside diameter that will fit over the bracket and turn the shit out of it. It will either shear or come free.
The other thing I might try is drilling a very small hole into the broken off bolt (on the broken side) and after you get it smokin hot shoot it with WD 40 and it will cool that bolt causing it to contract quickly from the bracket. It works really well most of the time.
Rear axle hub + new bolts (sheared them) hillstrubl Wanted 3 December 9th, 2013 08:52 AM
3 bolt to 4 bolt LHD PAS box conversion kjva Defender Technical Discussions 3 April 3rd, 2012 06:20 PM
Sheared axle housing chris snell Defender Technical Discussions 18 March 22nd, 2011 11:13 PM
95 3.9l 10 bolt or 14 bolt head kolvedic Defender Technical Discussions 12 June 25th, 2010 11:40 PM
