Sheared bolt size - Page 2 - Defender Source
Old November 28th, 2015, 06:01 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Originally Posted by Contractor View Post
I'd try sticking the bolt in the vise and then heating it up, but you are going to need O/A type heat (mapp might work). Go find a 4' long piece of pipe that has an inside diameter that will fit over the bracket and turn the shit out of it. It will either shear or come free. The other thing I might try is drilling a very small hole into the broken off bolt (on the broken side) and after you get it smokin hot shoot it with WD 40 and it will cool that bolt causing it to contract quickly from the bracket. It works really well most of the time.
Truly appreciate the info. I will try that shortly!
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
1971 109 3 Door (Sold)
Old November 28th, 2015, 09:37 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
So cannot find grade 8 bolts anywhere in town. Will a standard zinc bolt work until I can order better? Need the 110 up and running for work Monday.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old November 28th, 2015, 09:41 PM
the rover shop
shayne young
I'm sure that will be okay....just no high speed or rock crawling..
Old November 28th, 2015, 11:07 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Got it out...heat, wintergreen oil, heat, pb blaster, heat, sledge hammer, and repeat. Now looking for replacement bolts.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old November 28th, 2015, 11:34 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Nice....wintergreen oil?
Attributed to Shayne...
Old November 29th, 2015, 12:00 AM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Tip from DefendersNW. Never heard of it before but guess it helped.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old November 29th, 2015, 09:32 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Persistance triumphs! Glad to hear it came out.
Rear axle hub + new bolts (sheared them) hillstrubl Wanted 3 December 9th, 2013 08:52 AM
3 bolt to 4 bolt LHD PAS box conversion kjva Defender Technical Discussions 3 April 3rd, 2012 06:20 PM
Sheared axle housing chris snell Defender Technical Discussions 18 March 22nd, 2011 11:13 PM
95 3.9l 10 bolt or 14 bolt head kolvedic Defender Technical Discussions 12 June 25th, 2010 11:40 PM
