Sheared bolt in manifold - Defender Source
Old September 29th, 2016, 01:56 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I just sheared off the adapter I was installing in the manifold for a boost gauge. How do I get the part off that is still left? It's not threaded on the inside, that part came off, so I don't have any ideas of how to back it out.
Do I need to remove the manifold to do this?
Old September 29th, 2016, 02:00 PM
Parrie's Avatar
Parrie
Parrie Willette
1989 D90 P/U
I would say try an "easy-out" but not sure if you have enough room w/ the manifold on.
Old September 29th, 2016, 02:02 PM
Easyout or any type of bolt extractor.
Old October 6th, 2016, 06:45 PM
Ruthiford
Jason
1986 D110
Be careful using an ezout on this. They tend to swell small soft parts and make things worse.
Be sure to tell them Large Marge sent you....
Disco1-2 and p38 intake manifold bolt set the rover shop For Sale - Parts 0 December 2nd, 2015 10:13 PM
Sheared bolt size Ncrover725 Defender Technical Discussions 26 November 29th, 2015 08:32 AM
Rear axle hub + new bolts (sheared them) hillstrubl Wanted 3 December 9th, 2013 07:52 AM
Sheared axle housing chris snell Defender Technical Discussions 18 March 22nd, 2011 10:13 PM
Exhaust manifold bolt size ? Chris Velardi Defender Technical Discussions 2 July 20th, 2010 11:33 PM
