Sheared axle housing - Defender Source
Old March 20th, 2011, 04:30 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Ever seen an axle tube shear in half? You have now.
http://www.flickr.com/photos/defender90/5542417274/
Check out the map by the photo and you'll get an idea of how my day went.
Old March 20th, 2011, 10:59 AM
dchapman
Daniel Chapman
1999 D1
An on-board welder would have probably been cheaper than the tow truck bill.
Old March 20th, 2011, 11:17 AM
chris snell
Chris Snell
87 Ex-MOD 110
Yeah, a Power Welder is definitely on my list. Also going to start carrying a jack stand or two and an air-driven grinder.
USAA paid all but $200 of the tow.
Old March 20th, 2011, 02:25 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
wow.. were you wheelin' or just driving on the road when it gave way?
Legend in My Own Mind.
Old March 20th, 2011, 02:28 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Scary....Details please!
Old March 20th, 2011, 02:40 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Yes.
Congrats on this though.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 20th, 2011, 03:40 PM
dchapman
Daniel Chapman
1999 D1
How will you spin your air-driven grinder? Co2?
You need a York pump on your 90.
Old March 20th, 2011, 08:05 PM
chris snell
Chris Snell
87 Ex-MOD 110
Originally Posted by Buckon37s View Post
Yes.
Would you feel confident in a re-welded tube? I haven't pulled it apart yet but I'm guessing that the original weld just didn't penetrate well. The truck has very little rust. My biggest concern is that the other side of the tube may have the same defects.
Old March 20th, 2011, 09:10 PM
I would get a Disco 1 rearend and use that. Cheap and readily available
Old March 20th, 2011, 09:30 PM
I have purchased a D1 axle in the past, complete for $150.
Old March 20th, 2011, 09:34 PM
carlosz's Avatar
carlosz
Carlos
I have seen such carnage while working on heavy over the road tractor trailers, spring perches come loose and the normal turning under load wears on the housing and it breaks... 3 or 4 times, but it is my first time seeing it on a light duty vehicle.
darn...
Old March 20th, 2011, 09:36 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Like the others said time to buy a disco axle.
You should be able to get one for under $150. Place a wanted post on the Solihull site, call Keith @ rovertracks, craigslist and check car-part.com
Old March 20th, 2011, 10:00 PM
dchapman
Daniel Chapman
1999 D1
There is no problem with welding that. Only challenge is getting it straight. Either way, welding it should get you through the week and get you home, even if it's not perfect.
Old March 20th, 2011, 10:30 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I have done it before. If you were here I would do it for you. You can trench the crack and burn in. A small, simple truss will make it stronger than stock. Pretty simple. Or, like others have said, you can swap. Up to you. Good luck.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 20th, 2011, 11:25 PM
chris snell
Chris Snell
87 Ex-MOD 110
Thanks Buck, I appreciate the offer. Ben Little was with me when the tube broke and he suggested the truss, too. Says he's gonna do them for his truck.
Dan sees where I'm going with this. I'm not trying to cheapfuck out on replacing the tube; I just need to get the truck home safely from Moab to Colorado Springs and don't want a wheel coming off on Wolf Creek Pass. As soon as I get home, I'm pulling the entire assembly and the old tube is going in the trash.
On that note, this may be a 1 in 1000 freak occurrence but now that I have seen it happen to a very well-maintained truck on a pancake-smooth packed sand road, I don't doubt that it could happen again to someone else. I will have all of my rover housings trussed from now on. If this accident had occurred at higher speeds or on rougher terrain, I could have been a dead man.
Old March 20th, 2011, 11:58 PM
dchapman
Daniel Chapman
1999 D1
Be sure to inspect the axle and make sure it did not bend.
Old March 21st, 2011, 12:32 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
If you can get ahold of a good welder, you can burn it in with a straight-edge. It wont be perfect, but it will get you home without issue. I broke my front-end in half completely in glamis and bribed a tow truck driver to let me use his welder while he looked the other way. It got me home without issue. Later I squared it up (it was shockingly close) and trussed it. Welds can fatigue over time, and the axle's OD is really too small for the weight over it. I am surprised it does not happen more often. Good luck!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 21st, 2011, 01:22 PM
chris snell
Chris Snell
87 Ex-MOD 110
Update: it was a bad weld from the factory. Poor penetration and it pulled cleanly in half as though sawed. I have a guy welding it back together for me. It has been resting on the RoverTracks axle and brake caliper. I'm going to throw a stock halfshaft back in it for the drive home.
Check your axle tube welds! I will never blindly trust another rover axle tube.
Old March 22nd, 2011, 11:13 PM
chris snell
Chris Snell
87 Ex-MOD 110
Photos:
http://www.flickr.com/photos/defende...7626204989387/
axle
Series III Rear Axle (Drum-to-Drum or Axle Housing) Lriwater Wanted 0 September 7th, 2009 08:08 PM
24 Spline Axle Shaft (Long Side) + CV Joint + Rear Housing mudrover For Sale - Parts 0 March 2nd, 2005 09:48 AM
axle housing redrover Defender Technical Discussions 5 June 19th, 2004 02:14 AM
D90 rear axle housing! TwisteD90 For Sale - Parts 0 January 13th, 2004 07:55 PM
