Shark fin radio antenna - Defender Source
Old February 18th, 2005, 03:10 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
Question Shark fin radio antenna
Radio reception in my area - just north of Los Angeles is pretty poor. I have heard the shark fin antennas seen on BMWs are very good. Anyone have experience with them? I figured to mount it on a scoop lid for the engine bay intake. With a ST, no other place to so with it.
Old February 18th, 2005, 08:08 PM
artm
Arthur Maravelis
97 SW
I always thought the best antenna is the stock type aerial. Anything smaller needs more amplification (active) to match performance.
These little jobs may look cool (not for me) but I can't believe they work better.
I assume you're referring to FM reception so perhaps a better radio is in order?
Old February 18th, 2005, 08:12 PM
ripp2002's Avatar
ripp2002
L C
94 Defender 90
Best bet would be satilite. Its about 10.00 per month. Sirius has a deal for life time for 499.00. No matter where you go it always works just the same. XP is a little more expensive and has a few more channels. Both have everything from porn to comedy and every type of music you like. You can get a free 48 hours of listening time on either website. Systems are slighting more then regular but reception is great. I have crappy reception in my area too. Its great for long trips you never have to change the channel or listen to bs ads after every song.
Larry
Old February 20th, 2005, 01:34 PM
paulb's Avatar
paulb
Paul / Boultbee
Tx, I spoke to a friend who has the shark fin - no better in the hills of the area. The radio is a 9813 Alpine so pretty good model and 1 year old. I have thought about a seperate amplification for it but I think first will be a re-install. I had it done professionally (unfortunately I was new to the area and use a company called Al &Ed who no one speaks highly of) and think it was done incorrectly. Once the rain stops - on a hill and we have had 10 inches this week and 2 bigger storms coming in - I'll dash mount it and see.
Old February 21st, 2005, 02:08 AM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
If you have a CB or an interest in getting one you can use your CB antenna for your radio too. You would get better reception with a 4' or 5' CB antenna, if you are looking for a good stereo place I would recommend "Mobile Fantasy" they are in Northridge, they do very good work.
Old February 21st, 2005, 07:25 AM
scoloco's Avatar
scoloco
'94 D90 ST
Originally Posted by sheki
If you have a CB or an interest in getting one you can use your CB antenna for your radio too. You would get better reception with a 4' or 5' CB antenna.
I've heard of this. Having bent and snapped my aerial, this looks like a much sturdier and better replacement method. What is the 'magic' box needed to do this?
-scott
Old February 21st, 2005, 10:41 AM
Hmmm, A CB antenna is tuned for about 35 MHz while a FM antenna is tuned for about 100 MHz so I don't know how well it would work. I bought a new antenna and a new cable to go from the antenna to the radio, both improved reception greatly! The antenna I bought is about twice the length of a normal antenna but it collapses to 1/2 the length of a normal antenna for trail use. When I pulled out the cable it was all beat up and spliced so that also made a big difference.
Old February 21st, 2005, 12:09 PM
paulb's Avatar
paulb
Paul / Boultbee
Yep, I think my antenna cable is shot but I want to replace it anyway. . Its raining until Thursday so nothing is happening for a while. I'm going to love saying this so here goes...
Is length really that important? Some of these smaller but thicker, rubber coated antenna pitch themselves as having the best pick up reception.
If I can not get it how I like it, time to get the 6 CD changer or iPOD mount and bag FM for AM sports & road updates only.
Old February 21st, 2005, 02:15 PM
scoloco's Avatar
scoloco
'94 D90 ST
Tuning a CB antenna is for trasmitting more than receiving. Not going to transmit with an AM/FM radio. As long as the antenna works for reception it will do. The one downside to this setup is that you cant have the CB and listen to tunes at the same time. I'm pretty sure anyway.
Old February 21st, 2005, 02:30 PM
Yes it's doable but not optimal
http://www.firestik.com/Tech_Docs/am-fm-cb.htm
I am no antenna expert but if you could get an antenna about 1/2 wavelength (54") that would be great otherwise 1/4 wavelength (27") would be fine.
Old February 21st, 2005, 11:24 PM
sheki's Avatar
sheki
David Shechter
I have the Firestik set-up and they make a box/splitter for connecting the CB and radio, they will both work at the same time. You can order direct from Firestik.
radio
1997 Radio Antenna Removal ronward Defender Technical Discussions 12 August 8th, 2007 08:21 PM
satellite radio antenna install nykx Defender Technical Discussions 8 November 29th, 2004 10:49 PM
Power Radio Antenna Kimos Defender Technical Discussions 0 October 21st, 2004 08:45 PM
94 Radio antenna part # flippedrover Defender Technical Discussions 5 August 23rd, 2004 08:49 AM
XM Radio antenna install Location - Where? COSteve Defender Technical Discussions 37 July 11th, 2004 07:50 PM
