Shaking in 3 and 4th gear - Defender Source
Old August 29th, 2015, 09:09 PM
emah's Avatar
emah
Ed Mah
1993 NAS D110
I just started to get this terrible shaking after I shift into 3 and 4th gear and you can really feel it on the floor boards and the steering wheel. I have a NAS 110 and initially I thought the tranny or t-case was tired and going because I still have the Lt77 in it. I checked the fluids and good. Diffs and ignitions wires good. Engine oil good. I use only Amsoil. So I think I narrowed it down to misfire, bad rotor or cap or bad bushings. I don't know how to check the rotor or cap but they look pretty new as do the wires. The radius arms bushings on the other hand look compressed and worn out. Let me know what you think of the bushings and your thoughts of what else it may be or that Should check. Tires and balance are good.
ID:	128311   Click image for larger version
ID:	128313   Click image for larger version
Old August 29th, 2015, 09:22 PM
Those bushings look fine. I would look at u-joints first.
Old August 29th, 2015, 09:38 PM
Agree U joints and also check to make sure your propshafts haven't lost any nuts. Had a similar experience to yours traced to loose nuts.
Old August 29th, 2015, 09:56 PM
emah's Avatar
emah
Ed Mah
1993 NAS D110
Good pt guys. I did grease up the shafts and ujoint but didn't check on the wear. Yesterday I did notice that when cruising at 50-65 mph that if I let off on the gas and back on the gas again there was a damp thump sound. Ill go check the u=joints now.
------ Follow up post added August 29th, 2015 07:01 PM ------
John and Chris,
The joints look good and tight...no slop. All nuts and bolts there.
LT77 stuck in 4th gear sonoronos Defender Technical Discussions 14 December 5th, 2013 09:59 PM
Charlotte Area Cars and Coffee- North Lake Mall I-77 ext 18 Sat Feb 4th! MC36 Misc. Chit-Chat 0 January 27th, 2012 10:12 PM
Violent shaking d-90 bar11 Defender Technical Discussions 20 August 13th, 2011 06:36 PM
Shaking on Acceleration 2.25 diesel Jpayne Defender Technical Discussions 34 September 16th, 2010 03:19 AM
Clicking in 4th and 5th gear Cred Defender Technical Discussions 6 August 11th, 2010 04:49 PM
