Shakes violently - Defender Source
Old September 28th, 2015, 04:55 PM
cappy
Brian Cappy
1987 110
Shakes violently
87 defender 110, England import, switched from right to left drive. Steers great 95% of the time
but if u hit a bump, while braking the steering wheel shakes violently. Replaced steering damper
didnt help. Whats Next ??
Old September 28th, 2015, 04:59 PM
Steering damper is the wrong place to start!
1. Hub swivel tension ... How To Adjust Your Swivel Pin Preload - Land Rover Forums - Land Rover Enthusiast Forum
2. track rod and steering rod ends ... check for wear ... they are cheap to change
3. bushes - check with big pry bar
4. shock absorber - if they are worn it can lead to steering shake
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Welcome to the Forum.
Plenty of info in here about your problem. The search is your friend. Here's one example: Death Wobble Eradication - Defender Source
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old September 28th, 2015, 05:45 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Check your pan hard rod bushings and the rest of them. Old truck. Probably old bushings.
Swivel preload could cause it also; however, it is the most complicated . Check your bushings first.
You little rebel, I like you.
Old September 28th, 2015, 06:57 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Panhard Rod Bushings (and bolts)
Steering box bolts may have loosened
Regardless of the symptom, always, always check or just blindly replace the rear link - chassis bushings.
Old September 28th, 2015, 07:47 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
pan hard rod bushings or bolts ,,,, please let us know the result....
good luck with your search
Old September 28th, 2015, 08:28 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
After doing everything else, mine was swivel preload. I second LeastOnce completely.
My front end shakes Pinballking2 Defender Technical Discussions 21 September 17th, 2014 10:37 PM
The shakes..while driving.. arbik Defender Technical Discussions 4 December 7th, 2005 12:08 PM
