SG Stage 2 w/ 3rd link - Defender Source
Old January 31st, 2004, 01:40 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
Besides cost which I already know is high - I am curious what the forum thinks about this kit. I posted a question about SG and it seemed like most people thought their brushguard and sliders were pretty crappy, but what about the suspension kits. I would like the lift and the added off road capabilites the Stage 2 brings, but don't want to change out driveshafts, etc to accomadate it. Will I have to?
Also, becuase the D-90 is my daily driver want to keep the on road characteristics as close as possible to stock.
Thanks.
Old January 31st, 2004, 02:02 PM
jperakis
James Perakis
94 ST
thats what i have on my truck and i now love it, however i did encounter some serious problems while installing it. The big problem was that the front 12" shock was too long. I had to switch down to a 10" in order to prevent buying the new driveshaft and all that other junk.
The 3 link its self it amazing.
my advice is to buy only that from safari gard. You can get a bad ass OME kit or something along those lines for a ton less than the 2K they want for the stage 2.
If you'd like, i'd gladly let you take my truck out, to test it for yourself.
remember two things...
Old January 31st, 2004, 02:12 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
James,
Are you still in orange today. My wife has a bunch of crap planned this weekend, but I could probably take a couple of minutes to swing by if you around. I'm in Irvine so we are pretty close.
Joe
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old January 31st, 2004, 07:12 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
I can tell you that their new springs are far more better then the old ones and you should be ok driving it everyday. Since you are planning on adding 3-link I would try to find another way to mount the front shocks. Since the front shocks has studs, the amount of articulation that the 3-link give will give to much stress on the stud, so you need to find a shocks with lower eye mount to lower the binding. I know of 3 front Fox shox that broke the stud and myself broke two rancho shock studs, and that's why I went with external shocks mounts so I can run eye/eye shocks.
Honestly, if you are going to spend $1500 on the stage II, I would pay a little more money and get coil overs, trust me they are not that expensive compare to SG suspension.
World traveler
Old January 31st, 2004, 07:42 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
I think the latest Stage II kit has looped ends on both ends now. I had moderate vibration from the rear driveshaft after installing my Stage II, instead of replacing the driveshaft, I installed the Rovertym trailing arms that use bushings to adjust for pinion angle. It eliminated all vibration for less money than driveshaft, is very heavy duty, and has better underside clearance than stock parts and eliminates the bushing bind that you get from the lift.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old February 1st, 2004, 01:13 PM
jperakis
James Perakis
94 ST
sorry joe im still in SD and and my car's gonna be in the shop for at least a week now. ill be sure and let you know as soon as i do get it back.
Safari Gard 3rd Link vs QT arms rgrrvr Defender Technical Discussions 5 November 2nd, 2007 09:40 AM
New SG HD Drag link TDI Guy For Sale - Parts 3 June 23rd, 2006 08:05 AM
SG JEK Stage II fleabus Defender Technical Discussions 7 September 1st, 2005 04:42 PM
SG Stage II Springs and Shocks-- MISC neo812 For Sale - Parts 3 January 23rd, 2005 11:56 PM
SG 3 link pro's con's Bowtracer Misc. Chit-Chat 5 October 30th, 2004 12:11 PM
