Severe frame rust! - Defender Source
Old March 23rd, 2005, 05:13 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Severe frame rust!
I pulled the cross member to install my new 3 link thing! Everything was going smoooth till I removed the cross member!!! The corrosion is so bad that I have nickel size holes in the frame! Now what!!!??? I guess I will have to assemble drive to a welding shop remove the y & new cross member cut & weld & reassemble.
F#%$!
Old March 23rd, 2005, 05:16 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Yeah, pretty common occurrence on defender frames. I don't think they paint the frames behind the crossmembers. I found surface rust when I took my crossmember out.
How in the world have I spent this much money and still don't have a running vehicle?
Old March 23rd, 2005, 05:25 PM
I did one on a SII for a friend about 6 months ago. It took about 4 hours to cut off the old, clean up the frame and weld on the new x-member. It was pretty straight forward.
Old March 23rd, 2005, 05:28 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Dave, I don't want to weld the cross member in! Do I!?
Old March 23rd, 2005, 07:18 PM
If it is the rear crossmember yes you do. Are you sure we are talking about the same thing? I am talking about the huge hunk of metal that the back bumper bolts on to. Snap a photo of what you are talking about.
Old March 23rd, 2005, 08:16 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Peter, you do not have to weld in the 3-link x-member. I would do what you said. Have the frame patched and then bolt in the x-member. Just paint behind it before you install it. I did not have this problem since I installed a new Galv frame..
Legend in My Own Mind.
Old March 23rd, 2005, 08:19 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
After you patch your frame, I'd highly recommend some Waxoyl, everywhere on your undercarriage. That stuff works.
Old March 23rd, 2005, 10:55 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
My frame is almost rust free EVERYWHERE except on the inside of the front cross member. I will post a picture!!
Randy we all have seen! Your truck gives me sumthing to aspire too!
Old March 23rd, 2005, 11:11 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
What kind of prep do you need when applying waxoyl to the frame? Just clean it, sandblast it, etc?
Old March 23rd, 2005, 11:18 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Dude that kid kinda gets on ya. Thats why I am here! Too escape that!
Waxoil can be applied over rust! BUT you should really remove the flaky shit first! Hard to get inside the framebut the stuff really works if applied correctly.
Old March 24th, 2005, 07:46 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
No sandblast. Remove the flake, repair what you can. Ospho what you can't. Then apply.
Basically make sure you have no dirt on there during application.
Old March 24th, 2005, 11:21 AM
cbass's Avatar
cbass
Bradlee Duncan
What's "Ospho"??
Old March 24th, 2005, 11:24 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
It is rust converter! It has a watery consistancy you brush it on let dry & then paint.
Old March 24th, 2005, 11:25 AM
jabber
m j
110
Originally Posted by cbass
What's "Ospho"??
I hear the stuff is fantastic! You have to buy it in bulk though... Or at least that was my experience.
Old March 24th, 2005, 11:32 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Ace is the place!!!!! Ask your helpful hardware man! If you can buy localally I can & mail it to you!
Old March 31st, 2005, 02:18 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Here are some before & after & during the repair!
Name:	frame rust 001.jpg
ID:	2860   Click image for larger version
Name:	frame rust 002.jpg
Name:	frame rust 003.jpg
ID:	2862   Click image for larger version
Name:	frame rust 004.jpg
Name:	frame rust 005.jpg
How straight is a typical Defender frame? madcowdungbeetle Defender Technical Discussions 9 August 22nd, 2009 05:43 PM
FS NAS D90 take out frame, no rust ECR For Sale - Parts 8 June 13th, 2009 02:03 PM
Frame Rust. How Bad? Quimbola Defender Technical Discussions 18 February 20th, 2008 12:31 AM
