Service light on & no code - Defender Source
Old October 9th, 2012, 05:53 PM
wantone
Rick Thompson
94 ST #1222
My 94 service light went on recently, truck still runs the same, usual milage etc., and i check the boxby the ecu for a code & there is not one displayed. What is going on?
Old October 9th, 2012, 06:03 PM
bjf's Avatar
bjf
barry f
94 ST #395
It goes on at certain mileage points. Just needs to be reset.
Old October 9th, 2012, 08:27 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
if the light is red its emissions reset light every 83k if im not mistaken
No Mall crawler here
Old October 9th, 2012, 09:44 PM
peachyracer's Avatar
peachyracer
Peter Stolz
My wifes '94 D90 POE #1500
Well, it hasnt happened on my defender in the time i have had it, but it did happen on my 99 Disco. It wasnt the "check engine" light, it was the "service engine" light. It was a little brown relay up under the discos dash. Not sure where the defenders is, probably in the fuse panel.
To reset it, i made a little jumper wire and stuck it into the little holes on top. Reinstall...no light. You might even be able to just yank it with no vehicular complaints.
Pete
Old October 9th, 2012, 10:25 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
yes brown box little hole on top of it insert a drill bit and it will short the contacts and reset the unit
Old October 10th, 2012, 10:13 AM
wantone
Rick Thompson
94 ST #1222
thanks gentlemen! i will find the brown relay and proceed.
Old October 10th, 2012, 10:16 AM
maleger
Marc-Andre Leger
I just took it out... no problems since. I maintain my D90 much more than what is recommended anyway ;-)
Old October 10th, 2012, 10:21 AM
bjf's Avatar
bjf
barry f
94 ST #395
I took the bulb out. It came on at 50,000 miles.
ht, service
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
Red Service Engine Light kleedee Defender Technical Discussions 5 June 14th, 2005 01:08 PM
105,500 emission service? Chaucer Defender Technical Discussions 0 June 12th, 2005 11:19 PM
service engine light Milo Defender Technical Discussions 3 September 5th, 2004 09:58 PM
Check Engine light, code 17 mchombeau Defender Technical Discussions 3 March 17th, 2004 06:12 PM
» Defender Registry
Big Bird
owen
YELLR
Cactipus
Add your Defender
