service labor estimate resource - Defender Source
Old May 21st, 2015, 01:12 PM
I'm trying to figure out the Land Rover reference for estimated hours labor to replace a head gasket on a TDI. Is there something online for that? That would be a handy reference to have for any other work, to compare what a shop is telling me versus a standard.
Mark Kellgren
KM4BOR
Old May 21st, 2015, 01:24 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Depends on the shop I suppose, hard to say it's fair to use something like that here in the states since Tdis were never here. Typically book times involve vehicles that the dealer sold/saw at some point. That being said, perhaps you can contact Jimmy Kelly directly and get info from him
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Not exactly what you are looking for, but here is the labor operation times for the heads on a NAS.
File Type: pdf NAS Heads from Defender Labor Operation Times.pdf (42.5 KB, 23 views)
Old May 21st, 2015, 01:25 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Which shop is doing your work?
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old May 21st, 2015, 01:26 PM
import clinic in Charlotte.
Mark Kellgren
KM4BOR
Old May 21st, 2015, 09:50 PM
The warranty time for a cylinder head including decarbonising, resurfacing, and grinding in the valves is 9.6 hours, so I would figure anywhere from 15-20 hours for a head gasket job at an independent shop.
Old May 21st, 2015, 10:13 PM
WTF? Dont you have tools?
-Jeff
I did my HG last Nov, snd here I sm again. Im done with rework.
Mark Kellgren
KM4BOR
Old May 21st, 2015, 10:28 PM
That sucks. Im assuming you used new bolts.
-Jeff
No. lesson learned
Mark Kellgren
KM4BOR
Old May 21st, 2015, 10:35 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Bolts aren't 100% necessary on tdis like they are v8s
Old May 21st, 2015, 10:37 PM
Well, I found the problem. How did you want to pay the diagnosis fee? Paypal?
-Jeff
Steve at safari gave me that diagnosis already. For free yotch.
Mark Kellgren
KM4BOR
Old May 21st, 2015, 10:39 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
I call bull shit. Aren't they supposed to stretch into place.
Old May 21st, 2015, 10:42 PM
M&D says to measure them. 300 tdi manual says up to 3 times. Stephen said 2 max but he always uses new since they are not expensive. I had my head shaved and pressure tested in Nov when I did it. This sucks.
Mark Kellgren
KM4BOR
Old May 21st, 2015, 10:44 PM
tjfslaughter
thomas
Burbon
un cool. Did you use an Erling gasket?
Old May 21st, 2015, 10:45 PM
Mwm genuine gasket for 2.8
------ Follow up post added May 21st, 2015 10:45 PM ------
While you are working on your truck, i found you some brake pads.
http://www.defendersource.com/forum/...-em-62380.html
-Jeff
I found some pads for you too. Get busy.
https://boyzdestroyed.com/sex-toy-pr...her-knee-pads/
Mark Kellgren
KM4BOR
Old May 21st, 2015, 10:49 PM
tjfslaughter
thomas
Burbon
I hope you get it sorted out!
Old May 22nd, 2015, 07:00 AM
Thanks for that, but that's crazy. Good machine shops here clean, shave and pressure test heads in an afternoon for around $100. How does one spend 10 hours on one head?
And I can have the head out myself in 2-3 hours. How can a professional shop spend a full 20 hours on one head?
Mark Kellgren
KM4BOR
Old May 22nd, 2015, 08:03 PM
The labor I gave for the warranty time is including the machine work, not 10 hours for doing the machine work. I wouldn't trust the work of a machinist that is only charging $100 to do a cylinder head because in my experience you get what you pay for with machine work.
The amount a shop charges has nothing to do with how long it takes them. just based on looking at a 300 Tdi, I could probably do the head gasket in under 6 hours easily, but that doesn't mean that I would only charge 6 hours. I also quoted you on the high side for the customer pay labor based on the fact that the shop probably doesn't do a lot of 300 Tdi work, so they will probably charge more since they will expect hiccups. Mechanics are paid by the job, not hourly, and they don't work to make 40 hours a week.
Old May 22nd, 2015, 08:42 PM
Adventure-expedition-overland-tactical certified.
Does that mean car camping?
Old May 22nd, 2015, 08:54 PM
There is a fundamental difference between hours charged and actual time elapsed.
Its a shitty concept ... it would be much easier if the shop quoted in 'complexity cost units'
Jimmy and I were talking about this last night ... for some tasks land rover mandates the shop has $60k of test gear ....and for others you just need a wrench; others have unknown complexity or risk ... rusty bolts, unfamiliar job ... Elapsed time is only one factor.
The cost to the shop of doing a particular task varies wildly. Unfortunately shops quote this in hours.
In reality the job may take 6 hours but the risk, unfamiliarity etc will cause the price to be padded to where they are comfortable they are going to make margin ...
Old May 22nd, 2015, 09:11 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Glad I do most of my own work...
$2250 @ 15 hours at a labor rate of $150
$3000 @ 20
service
NATO green paint code resource josh-man Defender Technical Discussions 45 May 26th, 2015 05:39 PM
Rover Resource in Connecticut? madcowdungbeetle Misc. Chit-Chat 5 November 18th, 2011 06:39 PM
Resource for oil cooler lines? MC36 Misc. Chit-Chat 11 September 25th, 2011 01:15 PM
Galvanizing resource NH, MA, ME Mark McDonough Defender Technical Discussions 8 October 22nd, 2009 11:07 AM
Clutch Estimate: mlw911 Defender Technical Discussions 4 November 20th, 2004 10:37 AM
