Service Engine Light Reset? Help!! - Defender Source
Old May 10th, 2011, 11:24 PM
N1ck B's Avatar
N1ck B
Nick
95 D90 ST
I would hate to start yet another thread on this subject however I tried to reset mine with inserting a metal pin in the brown unit behind the dashboard but as soon as I remove the pin the light comes right back on. Is there a specific sequence I'm missing (e.g. ignition on first, or last, .....??). Any advice and help on this would be much appreciated. I don't want to disconnect the light, but I've done the next easiest thing, put a piece of square black electrical tape.
Old May 10th, 2011, 11:29 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Remove the tape. There is a series of steps to take to reset it. Im sure someone will show you the link for it cause I have used the steps that were told on here to reset the thing myself. Its not going to hurt your truck if its not reset anytime soon.
Old May 11th, 2011, 12:49 AM
Pull the bulb.
Old May 11th, 2011, 04:01 PM
N1ck B's Avatar
N1ck B
Nick
95 D90 ST
Anyone else out there??? I was sure that I would be getting tons of responses on this one since I know that most of you would have already had this experience.
The fact that it will turn off and then turn right back on after removing the pin, does that mean that there is something wrong with the emissions system???
Old May 11th, 2011, 04:08 PM
airbornrover
William Skidmore
SIII 109 SW
Try lrfaq.org
Old May 11th, 2011, 04:30 PM
N1ck B's Avatar
N1ck B
Nick
95 D90 ST
Thanks. I tied lrfaq.org but it's mainly talking about Check Engine Light and fault codes, and I'm looking for the Service Light.
Old May 11th, 2011, 04:45 PM
We have a service light?
Old May 11th, 2011, 05:00 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
3 easy steps to turn it off. 1) Pull apart dash to get to the little brown box. 2) Unplug from the multi-plug and throw as far from you as possible. 3) Put dash back together...tada! If you need something to tell you when to service your Rover then by all means leave it in there.....but you have to reset it EVERY time you do a service, otherwise it will randomly come on!
Old May 11th, 2011, 06:09 PM
All it does is keep track of miles. Pull the bulb.
Old May 11th, 2011, 06:43 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
As I recall the last time I did it, the procedure was to turn the ignition to ON, but not start the engine, jam the paper clip in the hole in the brown box wait for the light to go out, turn off ignition. Should be good to go for another 50,000 miles.
engine, ht, service
110 Service Engine Light Reset newfD90 Defender Technical Discussions 4 August 18th, 2008 11:12 AM
Is it true? Service engine light reset? thelandroverguy Defender Technical Discussions 18 April 16th, 2007 07:54 PM
Red Service Engine Light kleedee Defender Technical Discussions 5 June 14th, 2005 01:08 PM
service engine light Milo Defender Technical Discussions 3 September 5th, 2004 09:58 PM
