serious leak? - Defender Source
Old April 15th, 2005, 12:24 AM
scubadanster
daniel park
1997 defender 90
serious leak?
hey all!
got my rig back....but now, after they did my OME suspension and changed my rough-road sensor....there's an oil leak at my passenger front tire.......anyone knows what that could be? have no idea.....doesn't look like brake fluid.....it's a slow drip....any ideas?
thanks.
-dan
Old April 15th, 2005, 12:47 AM
excanuk's Avatar
excanuk
Nigel Rigby
94 D90
Inner or outer side of wheel. If inner then probably swivel seal.
A couple of options: Fill with grease instead of oil. Replace seal, and or live with it for now and check oil level frequently like I do.
Old April 15th, 2005, 01:20 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Front passenger side? Well, your oil pump, filter, cooler and associated cooler lines are all above that general area.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 15th, 2005, 01:01 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
Is the oil dark like from engine? If not, the power steering hoses are around there as well. Those can and will leak.
"Uhh...I think they all leak like that."
Old April 15th, 2005, 01:31 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
If it's 'AT' your front tire, like you say, then I agree with Nigel, it's most likely the swivel.
It's 90WT Gear Oil that's in it (or should be) , the same color/stuff that's in your DIFFERENTIAL... If it's got grease in it then it's probably not leaking and it's something else..
Nicholas
Old April 16th, 2005, 11:39 AM
scubadanster
daniel park
1997 defender 90
I see...
thanks boys. where is the reservoir to see is it's low???
-dan
Old April 16th, 2005, 02:43 PM
Dan the Power steering res is on the PS wing, black cap with a short dip stick on the cap. I would try tracing the fluid back to it's source.
Old April 16th, 2005, 03:09 PM
scubadanster
daniel park
1997 defender 90
sounds good, thanks mike.
-dan
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
300 Tdi fule leak Questions!! Buckon37s Defender Technical Discussions 13 February 28th, 2005 02:32 AM
Vacuum Leak Eric Siepmann Defender Technical Discussions 2 November 25th, 2004 09:11 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
