Separating rear rotor from hub - Defender Source
Old September 26th, 2009, 07:11 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
ok, I am stumped. I have just about everything and can't get the effin rotor off the hub. On the back side of the rotor, is a flanged piece that holds the rear seal and behind the seal the bearing. It doesn't look like the rotor will actually fit over this piece, like it needs to come out first. Like maybe it is pressed in there. I am assuming it is just par of the hub and the rotor fits over it but that seems really odd.
I know these are supposed to be a b*(ch to get off but damn. Tried PB, hammers, prying, heat, cold and nothing seems to help
I don't see in it in the FSM at all or any of the sites that show a blow up of the rear axle.
The bad attached pic shows what I am looking at and the rear seal. The red line is the bottom of the steel flange holding the real seal at the top of it. Man, that sounds complicated.
any help is appreciated,
Bill
Bill
Old September 26th, 2009, 08:03 PM
Its just wedged on there badly from corrosion. Get a bigger hammer!
Old September 26th, 2009, 08:18 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Jim beat me too it, your not beating the F out of it yet. Once it breaks free it won't be hard. Dribble a little Kroil on the seam and go at it the next day.
Old September 26th, 2009, 08:20 PM
x2. I have put the rotor in the vice and beat the back half off. I should really know what this is called but I dont. The last time I replaced rotors my 150 pounds was hanging off a 40 inch pry bar and I had someone with a 3lb hammer working pretty hard.
Old September 26th, 2009, 09:03 PM
kolvedic's Avatar
kolvedic
Bill Lewis
Right bigger hammer, beer and friends! check. thanks guys
bill
Bill
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
