Self Bleeding Diesel Fuel System - Defender Source
Old March 29th, 2014, 09:31 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Have had lots more questions about diesel fuel line routing.
Here are a few pictures of an Isuzu 4JB1-T setup, but the same for any diesel install.
Routing = tank, sedimenter, 12V fuel pump, engine lift pump, Fuel Filter, IP, return line back to tank.
Pump wiring from 12V relay =
86 - ignition circuit - white (+) when key is on
85 - ground (-)
30 - Positive (+) from battery (usually taken off main starter lead)
87 - (+) when key is on
No need to ever worry about bleeding the system.
If you run out of fuel or you change the filter, simply switch on the key, wait a few minutes, start the engine, and drive away.
If you get a bad batch of fuel, note the drain screw on the sedimenter.
Drain as many times as necessary until you purge all the smeckley and then drive away.
ID:	92002   Click image for larger version
RDavisinVA
Old March 30th, 2014, 12:48 PM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
Any reason not to put the 12v fuel pump closer to the lift pump to shorten the electrical runs?
Old March 30th, 2014, 02:47 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Robert - any particular fuel line you like to use?
I am thinking of running the fuel line and return down the left hand side of the new build - IP, pump, filter of the OM617 is on that side. And I think I can keep the sedimenter on the outside of the left hand frame rail for easy viewing.
bleed, diesel, fuel
Rear self-leveling unit. ajh Defender Technical Discussions 25 September 23rd, 2015 10:59 AM
Bleeding TDI Fuel System isleofbones Defender Technical Discussions 5 October 21st, 2010 04:47 AM
10' SOTAR R-2 self bailing river raft kellymoe The Flea Market 0 February 5th, 2010 12:54 PM
any self service parts yards near London metric Defender Technical Discussions 0 April 29th, 2009 10:53 AM
Fuel system bleeding CDNRover Defender Technical Discussions 6 July 16th, 2008 01:05 PM
