Seized rusty bolts...What did you do? - Defender Source
Old September 9th, 2014, 10:12 PM
vw121
Pete
D90
When I tried to drop my tank guard 90% of the bolts snapped. I tried using generous amounts of PB Blaster, heating, extractors, but they will not come out. I am thinking my only option is to cut and weld on new threaded plates/studs. Am I unlucky or is this what most people had to do?
Old September 9th, 2014, 10:25 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
You've got bigger problems than rusty bolts....I would speculate that cross member isn't doing so well. But yes drill and tap is a way to go, save the welding for the cross member replacement.
Old September 9th, 2014, 10:36 PM
As always Bill has a very valid point. Not only is he is a Land Rover savant he is an expert marksman with a blow gun and a flame thrower. I would tap the rear crossmember with a small hammer and see what else gives way. From your photos, things don't look very sound and a rear crossmember is pretty easy to replace since you have the fuel tank already dropped.
Old September 9th, 2014, 11:04 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
I soaked mine for days and tried an extractor. It worked for some, not all. The rest I cut off and had some of the pucks with the threaded holes made at the local blacksmith shop and welded them on.
And agree with the above comments on checking out the crossmember in general.
Old September 9th, 2014, 11:10 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Don't sweet it, shit happens a lot with these! The faster you come to realization that it sucks and start drilling the faster you will be done! Start small and work your way up and it shouldn't take you more then a half a day good luck! As for the skid plate I would take an air hammer or chisel and just knock those nuts off haha I said it!! Good luck! Have fun with it! Bourbon always makes it more fun for me
Old September 9th, 2014, 11:19 PM
scrubs
henery
1974
Well said!!!
Old September 9th, 2014, 11:46 PM
Bill Larson
Bill Larson
Sweet talker you...
Old September 10th, 2014, 08:09 AM
ezzzzzzz
Mark Garrenton
Wear safety glasses! One small speck of rusty metal falling into your eye will have you at the optometrist's office for extraction. It isn't fun. Been there 30 years ago.
Old September 10th, 2014, 08:15 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Lol it's funny because it's true; I always remember to wear mine, till I forget...
Old September 10th, 2014, 08:19 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
to add to the above, I have found that you can get the cradle bolts out from the top with vise grips turn to the right..... : )
good luck with your search
Old September 10th, 2014, 08:56 AM
ezzzzzzz
Mark Garrenton
If you have the resources, weld a nut onto the exposed stud and use a wrench.
bolts
Seized wiper spindles?? Ben01 Defender Technical Discussions 4 September 16th, 2013 06:23 PM
Rusty Cage Bolts 61rover For Sale - Parts 1 April 22nd, 2013 04:10 PM
D90 Step Rails & Rusty Bolts aaronlam Defender Technical Discussions 21 February 2nd, 2012 08:04 AM
What seized your attention originally??? Cyborg Misc. Chit-Chat 27 October 31st, 2006 11:58 PM
