Sedimenter Question - Defender Source
Old March 10th, 2014, 02:58 PM
dlbriller
Doug
1987 ex-MOD 'Tithonus' Defender 110
Sedimenter Question
Over the weekend I pulled apart and cleaned my sedimenter (the NRC9708 type), mostly because I snapped off that stupid plastic drain plug. In the process I noticed that there was nothing inside besides the diesel and some gunk. Am I correct in thinking there's supposed to be some sort of plastic cone in there to force the actual separation process?
Old March 13th, 2014, 08:59 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Looks like it does have a piece between the two seals
Old March 13th, 2014, 09:29 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Yes there is suppose to be an inverted cone at the top of the open space.
This cone prevents fuel from going in the inlet and straight out the outlet.
The inverted cone forces the fuel down where water and particulate are deposited.
The cleaner fuel then flows upward around the edge of the cone and out.
I actually build sedimenters with metal drain screws that don't break off when you try and unscrew or tighten them.
We supply an all metal model and one with a see thru glass that mounts on the inside of the frame rail.
They are a little more expensive, but much better quality that OEM and have Viton seals.
RDavisinVA
Old March 14th, 2014, 11:21 AM
dlbriller
Doug
I thought so, anyone know where I can procure a new cone? I'm hoping to to avoid having to buy a whole new sedimenter since there are many other bits and pieces requiring funding as well.
Old March 14th, 2014, 01:06 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Not all cones for the CAV units are interchangeable.
I have new plastic take out cones and metal thumb screws, but no guarantee the cone will fit your sedimenter.
I use to remove the plastic cones and replace them with aluminum ones when I added heat exchangers for use with WVO, but now build my own higher quality sedimenters.
RDavisinVA
Slider Question kellymoe Defender Technical Discussions 13 January 24th, 2006 04:52 AM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 12:30 PM
