Sedimenter and Lift Pump Fitting Size - Defender Source
Old July 17th, 2015, 02:52 PM
I was pondering putting the sedimenter back into my truck, which was removed when I did a dual tank setup. Anywho, it has those same goofy tube/flare fittings with the nylon tube heat fit over the metal tube.
I did a brief internet search but could not see anything as to what the actual fitting on the sedimenter is. I pulled one off and it is a 1/2-20 thread with a female flare inside. That seems to match up exactly with a 5/16" SAE flare. 5/16" is an oddball size, so I would need to go to a speciality fitting place to get one to try.
Before I waste any more time looking into it, I thought I would ask if anyone ha already done the checking into this. If it is SAE, it would be easy to get an adapter to a more normal fitting size.
Old July 17th, 2015, 03:06 PM
I see JIC is the same thread as well. But that seems less likely.
Old July 17th, 2015, 09:20 PM
The flare inside the lift pump does appear to be 45 degrees as best as I can measure, so I will give an SAE fitting a try.
Old July 17th, 2015, 09:33 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
I used the 1/2 20 with a barb...went to clear from there. Yes...it takes some heat and time...but makes for a clean install and IF there is a leak...easy to find. After heating and attaching tube to barb fitting used fuel injection hose clamps...works very well....and angles are not an issue....
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old July 17th, 2015, 11:30 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
If it's Lucas CAV I can dig out my CAV catalogs and see what I can find.
FWIW I took out all the CAV filter bits and went with a Racor setup.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 18th, 2015, 04:01 PM
For what it is worth, I do clearly understand how the stock fittings work and how to use them. I do also know of all the aftermarket options for a sedimenter replacements.
The point of this thread was to determine the type of fittings used in the genuine sedimenter and lift pumps. I'll pick up and test an 5/16 SAE 45 degree flare fitting in a couple of week after my holidays and update this as it appears nobody else has already looked into it.
Old July 18th, 2015, 04:09 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I use a 1/2 20 genuine all metal fitting with a copper washer, then use rubber fuel line.
The original had a plastic looking olive connection (going on memory), but anyway, I have a drawer packed full of that stuff if you need any.
RDavisinVA
Old September 25th, 2015, 08:33 PM
Forgot to get back to this one. I picked up the -5 SAE Flare adapters and they do fit and seal, although I'm not sure that is the intended fitting. As per Robert's suggestion, I also picked up some plain fittings and used copper washers to seal and went ahead with that route.
I used -5 ORB x 1/4" FNPT adapters. Removed the o-rings from the ORB end and used copper washers. This works with both the sedimenter and the lift pump. This seemed a good fit. With the 1/4" NPT, you can then use hose barbs and hose, or compression fittings and tube or flare fittings and all of those are available at any hardware store in the plumbing section, which was the main goal. I've used 3/8" nylon tubing, similar to stock and brass compression fittings.
The hardest part is first getting the -5 adapters as it is an odd size and most places don't carry it and jump from -4 to -6.
ID:	130792   Click image for larger version
Old September 25th, 2015, 10:06 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Looks good.
RDavisinVA
Old September 27th, 2015, 09:40 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I love the idea of writing the date on the filter.
Old September 27th, 2015, 11:22 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I always write the date/miles/oil on my filter in case I forget to put it in my book.
I also started doing it on hoses with a silver Sharpie.
Rent my
Old May 30th, 2017, 02:17 AM
Naplm00
Matthew
Jon can you be more specific on the fitting used on the stock lift pump? I cant seem to find or have ever heard of -5orb or Sae flare fittings.
Im still trying to figure out of SS braided lines and earls/russell's fittings is worthwhile
is 1/2x20 inverted flare the ticket?
EDIT: back from the dead
Old May 30th, 2017, 05:49 AM
Naplm00
Matthew
Edit again, nevermind
Brake line fitting size and thread Chris Velardi Defender Technical Discussions 22 August 26th, 2017 11:19 PM
Diesel Sedimenter (Original?) may take a filter Naplm00 For Sale - Parts 2 June 29th, 2015 11:29 PM
Sedimenter Question dlbriller Defender Technical Discussions 4 March 14th, 2014 01:06 PM
Tdi sedimenter new willtillery For Sale - Parts 5 January 11th, 2012 11:48 AM
Bottom section of 110 sedimenter michael67 Wanted 0 May 11th, 2011 11:41 PM
