Security Help - Defender Source
Old May 23rd, 2013, 07:33 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Security Help
Ok so I just bought an HMMWV. I know, not Land Rover, but I need some insight. It is 24V, very military, with no ignition switch and a cable and padlock to lock the steering wheel. I would hate for someone to cut the cable and drive off with my new project. It is also my first diesel, and I find it strange I have to wait for the light to go off before I can crank it over. So here is my question, what is the best way to secure this truck? I thought about a keyed switch to the battery terminal, maybe adding a key ignition like on the civilian H1 (but I want to keep it true to its roots and keep the ignition rotary switch on there now). Any input greatly appreciated!
MUDSUX
Old May 23rd, 2013, 07:44 PM
Either a battery cut off or a secret kill switch.
Old May 23rd, 2013, 07:48 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Pictures!
Old May 23rd, 2013, 08:03 PM
It depends on your neighborhood as well. I can put $100 bill under my windshield wiper and come out and find it in the morning.
-Jeff
ahhhh how the 1% choose to amuse themselves ....
Old May 23rd, 2013, 08:25 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Post a sentry on it?
There's only one thief in the Marine Corps; everyone else is just trying to get their shit back.
In all seriousness, do the battery cut off switch. Between that and the fact that the 1% (of us that have served, you know, the other 1%...) aren't likely to come across your HMMWV and reach in and play start your engines you should be good.
Old May 23rd, 2013, 08:29 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
How do you kill a diesel? Is there one wire that would do it?
MUDSUX
Old May 23rd, 2013, 08:32 PM
There might be an electrically controlled anti-dieselling switch on the diesel pump. Basically the pump won't pump fuel if this is disabled.
Putting a hidden switch in that lime would be a good way to prevent the engine starting or running.
Old May 23rd, 2013, 08:49 PM
Yes, to bad we all can't live in your NYC utopia where unicorns fart glitter.
A $100 on under my wiper blade would be as safe as in my wallet too.
Old May 23rd, 2013, 08:58 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Pretty sure my fuel pump is mechanical.
MUDSUX
Old May 23rd, 2013, 09:12 PM
I vote for a keyed switch. If you leave the regular switch, anyone can still start it regardless of how you lock it, unless you go with the battery shutoff. You can also look at padlocking the transmission gear, but electronic is really the only safe bet for someone with a bolt cutter.
HMMWV's are unGodly uncomfortable rides. Is this just a toy for you? One long trip will turn your unicorn glitter fart to a shart.
Mark Kellgren
KM4BOR
Old May 23rd, 2013, 09:28 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
http://www.parts-express.com/pe/show...ontent=Default
I havent looked at a wiring diagram, but i bet you can leave the regular switch in place, just hide one of these so that this has to be on for the starter to trigger. First time you are out trying to holler at bitches and you lose the key you gon be mad tho. Sittin there for hours waiting on aaa to bring they big ass wrecker.
If it were me I'd just hide a John Deere mower ignition switch somewhere and have JJ cut me a decal that said EMERGENCY WHEEL NUT RELEASE or something wild. Then when you lose the key you can pop into any wal mart, lowes or Home Depot and buy one off the shelf. Doesn't even have to be cut.
If you really wanted to throw off a thief though, I've seen brake locks. You park and hold the brake pedal, lock this little sucker down, and the brakes stay on. Just don't leave it for six months like that and don't lock it down hot (do h1 brake rotors warp easy?)
Old May 23rd, 2013, 09:32 PM
A Diesel engine my nature will 'diesel' which means it will run on its own ... If its all mechanical there still has to be a way to stop the engine. On a landrover TDI mechanical pump there is a switch that when has a voltage applied it allows the mechanical pump to run. To stop the engine you remove voltage and engine stops.
So you are looking for the anti-dieseling mechanism and interrupt that.
Old May 23rd, 2013, 10:14 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
-Jeff
Addy Please...!
Old May 23rd, 2013, 10:55 PM
Bill Larson
Bill Larson
Will I get a Christmas card?
-Jeff
Sure thing...an authentic Texas Card...
Old May 23rd, 2013, 11:31 PM
BlackField's Avatar
BlackField
Oscar
D110
What engine is in it? If its an early 6.2 you can splice into either the ECU mounted above the driver foot well or the Glow plug controller or any part of the line in between and open the path to either pin 3 or 6. It will likely not start even on a warm day.
You could work a kill switch into the neutral safety switch on any of the engine variants.
Oscar
Old May 24th, 2013, 12:27 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Is it an automatic? (maybe they all are? I am not an expert on that truck). If not and it is a manual, you can do a search and find a hydraulic cut out switch--it actually shuts off the hydraulics to a hydraulic clutch--that was pretty clever. Personally, I would use snakes. I think that is what they used in Gone in 60 seconds. It may not worked in the film, but if I saw a snake or a rottweiler in a truck, I would move on...
Old May 24th, 2013, 07:44 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Even on the mechanical fuel pump and mechanical injection pump motors, it's pretty common to have and electrical solenoid on the injection pump which cuts fuel flow when you turn off the ignition/power switch.
I don't know the GM6.2/6.5 motors at all but the solenoid is a pretty common item. You will find it on most of the old bosch rotary pumps used on VWs, Cummins, even on the old CAV pump on a 2.5 na rover motor which are all mechanical injection systems.
Old May 24th, 2013, 08:20 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Perfect. Thanks. I'll take a look at the Technical Manual and see if I can find it.
MUDSUX
Old May 25th, 2013, 08:02 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
IMO all turbo diesels (assuming it has a turbo) should have an intake air shut-off. Add one of those and leave it closed when not driving the truck. http://www.amotusa.com/products/air-...utterfly-valve
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
FS- D90 Tuffy Security Storage Box Holiday For Sale - Parts 6 July 6th, 2012 11:10 PM
green-guy, importing, and D90 security... Mike_D90 Misc. Chit-Chat 11 February 1st, 2012 09:38 PM
D90 Security Question: Break in Deterrent Methods Manimal Defender Technical Discussions 21 April 16th, 2009 01:02 PM
D90 Stock Cassette Deck Security Code? Erik Defender Technical Discussions 4 December 9th, 2004 06:56 AM
D90 security Campbell Misc. Chit-Chat 12 April 28th, 2004 02:46 PM
