Security Help - Page 2 - Defender Source
Join the Defender Source Community Today
Old May 24th, 2013, 07:20 AM
MUDSUX's Avatar
Like my Tatas?
A Diesel engine my nature will 'diesel' which means it will run on its own ... If its all mechanical there still has to be a way to stop the engine. On a landrover TDI mechanical pump there is a switch that when has a voltage applied it allows the mechanical pump to run. To stop the engine you remove voltage and engine stops.
So you are looking for the anti-dieseling mechanism and interrupt that.
Originally Posted by slorocco View Post
Even on the mechanical fuel pump and mechanical injection pump motors, it's pretty common to have and electrical solenoid on the injection pump which cuts fuel flow when you turn off the ignition/power switch.
I don't know the GM6.2/6.5 motors at all but the solenoid is a pretty common item. You will find it on most of the old bosch rotary pumps used on VWs, Cummins, even on the old CAV pump on a 2.5 na rover motor which are all mechanical injection systems.
Perfect. Thanks. I'll take a look at the Technical Manual and see if I can find it.
1983 110 Rebuild
Series 1
Old May 25th, 2013, 07:02 AM
Antichrist's Avatar
Tom Rowe
IMO all turbo diesels (assuming it has a turbo) should have an intake air shut-off. Add one of those and leave it closed when not driving the truck.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
FS- D90 Tuffy Security Storage Box Holiday For Sale - Parts 6 July 6th, 2012 10:10 PM
green-guy, importing, and D90 security... Mike_D90 Misc. Chit-Chat 11 February 1st, 2012 09:38 PM
D90 Security Question: Break in Deterrent Methods Manimal Defender Technical Discussions 21 April 16th, 2009 12:02 PM
D90 Stock Cassette Deck Security Code? Erik Defender Technical Discussions 4 December 9th, 2004 06:56 AM
D90 security Campbell Misc. Chit-Chat 12 April 28th, 2004 01:46 PM
