Seatbelt Tensioner Question - Defender Source
Old March 9th, 2009, 02:42 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I am getting close to installing the seat belts; however, they are all completely coiled in from being in storage. I haven't had a chance to take a close look at them, but they do not pull out at all just by alternating pulling and giving slack. I assume there must be some sort of release somewhere for this situation. Can anyone point me to it?
Old March 9th, 2009, 06:51 AM
If you're still using the old ones that were originally in the 110, then they have to be mounted at exactly the right angle to pull out and retract. There is a small weight on the side under the plastic cover, and if you pull the cover you can study the assembly and figure out what's up. Suffice to say though, if you go ahead and mount them at approximately a 45 degree angle, then they'll start working.
Old March 9th, 2009, 11:10 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Good to know, thanks Jim!
seatbelt
Slider Question kellymoe Defender Technical Discussions 13 January 24th, 2006 04:52 AM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 12:30 PM
