Seatbelt help - Defender Source
Old June 20th, 2016, 09:40 PM
Noyac40's Avatar
Noyac40
1985 D110
Seatbelt help
Does anyone have experience with D110 rear seatbelts? I removed the top from my truck for summer and bought a seatbelt roll bar to replace the mounting point. When I tried to pull the seatbelts out, they are stuck and wont release. I am thinking that when I removed them I let them roll up too much. Is there a trick to help release these? Adding pics below of the unit. Thanks
ID:	152268   Click image for larger version
Old June 20th, 2016, 09:45 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Make sure you hold them vertical as if they were mounted in the truck and tug on the belt over and over. Should release. If you're holding it upside down or sideways it won't release
Old June 20th, 2016, 09:49 PM
Noyac40's Avatar
Noyac40
1985 D110
Thanks, I will give that a shot.
Old October 6th, 2016, 11:24 AM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
My second row seatbelt is having problems releasing in that you have to pull VERY slowly to get it to unroll and will catch every few inches. So it's not totally stuck but very annoying for my 7 yo passenger to buckle up. It rolls up fine. What's needed to fix this? Thx
Old October 7th, 2016, 05:59 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
I use D2 seats for my 110 middle row. I had to increase the angle closer to vertical and had to put a major wrenching on it, but it fixed it
seatbelt
Help w/bolt specs- D90 rear seatbelt Bradford Defender Technical Discussions 2 May 16th, 2013 06:40 AM
rear seatbelt cgalpin Wanted 8 October 8th, 2006 09:05 PM
Rear seatbelt Q's Seanh Defender Technical Discussions 5 December 1st, 2005 07:40 AM
Seatbelt bracket Chaucer Wanted 0 April 16th, 2005 07:53 PM
Rear seatbelt removal chrisvonc Defender Technical Discussions 2 February 18th, 2005 03:04 PM
