seat lift needed - Defender Source
Old March 25th, 2004, 12:18 PM
jstrong98's Avatar
jstrong98
Jon Strong
seat lift needed
did a search and have seen that a few of you have made custom seat lifts, I'm 5-9 and a good 1-2" seat lift would be great. Any body have pics or specific directions on how to do this.
JS
Old March 25th, 2004, 12:46 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Here is Quinn's write up which I would assume you could modify to fit your needs:
http://www.defendersource.com/mod/seat_riser/index.html
Or at least give you a good referance.
Chris von C
[/size]
Old March 25th, 2004, 12:49 PM
1" by 1" hardwood, 2 pieces long enough to go from the front bolt hole on the seat to the back bolt hole on the seat, paint or stain the wood. I also used polyurethane bushings between the seat and the hardwood. You will also need longer bolts. There are only 4 bolts holding the seat down and they are pretty easy to get to. You could also use 1" x 1" steal.
Old March 25th, 2004, 02:32 PM
jstrong98's Avatar
jstrong98
Jon Strong
Thanks guys. Hey chris, I'm in you're neck of the woods. If you're going to be doing any wheelin in the south jersey area let me know. I'm a newb and lookin for some good trails within an hr or two.
JS
Old March 25th, 2004, 03:59 PM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Pick up aluminum spacers at the hardware store, and longer bolts.
Old March 25th, 2004, 06:49 PM
jstrong98's Avatar
jstrong98
Jon Strong
use the spacers to lift, or as washers with the wood ?
Old March 25th, 2004, 06:58 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Just pick up 1 in or 2in square tubing and cut it down to 2in each and put a hole through it. Stronger and safer and better looking than wood and not bootyfab like stacking washers.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 25th, 2004, 09:36 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
The ECR seat sliders let the chair move back another 3 inches. This is REALLY important to both me and my wife. The rails overhang the seat box in the back, giving much more lateral leg room. I think they will only fit an SW, tho.
Old May 8th, 2004, 04:12 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I used the box section steel method. bolted the steel to the seatbox and the stet to the steel, 1.6 mm -2 mm is plenty strong enough.
Mike Hammond
Old May 9th, 2004, 08:14 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Jon, Did you see the post in the "Hitting the Trail" section about a trip to central PA (Rausch Creek and Paragon). Come join us! People and trucks of all levels will be there.
Old May 10th, 2004, 06:47 AM
Kevin Baldwin
Kevin Baldwin
94 Defender 90 300Tdi
Check out: http://www.mudstuff.co.uk/MUD_Seat_Rails.html
Kev
Old May 11th, 2004, 09:48 PM
ronward's Avatar
ronward
Redsrover
None - sadly
Went by my local metal fab shop today and the owner GAVE me 8.5 feet of 1/8th x 1.5" square tubing. I'll be following Quinn's recipe, but might simply cut the forward ends square if I can find suitable caps for the tubes I have.
Time to break out the Sawzall...
Old May 12th, 2004, 10:23 AM
jstrong98's Avatar
jstrong98
Jon Strong
thanks for the invite, hadn't looked at the trail section in a while.
I have a place at the jersey shore during the summer, and my primary hobby (surfing) trumps everything when the surfs up. If it looks like no waves for the weekend I'll be there.
JS
110 seat part# needed Overlander Defender Technical Discussions 2 January 25th, 2008 09:49 PM
Baby Car Seat QUESTION Flagg Misc. Chit-Chat 5 August 4th, 2007 06:39 PM
Front Seat Covers Flagg Defender Technical Discussions 8 February 13th, 2006 07:45 AM
Rear Bench Seat + hardware Chaucer For Sale - Parts 8 September 29th, 2005 12:16 AM
D-90 3rd seat up front ?Possible - How? paulb Defender Technical Discussions 17 October 28th, 2004 07:26 PM
