Seat heater electrical install question - Defender Source
Old October 17th, 2015, 09:54 AM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
I just bought a heated seat kit from RN and have a question. The install manual states to connect one red wire directly to the positive battery terminal and the other (Orange) wire behind the battery. Both wires have a fuse to it before it reaches the wire harness. A third wire (black) is ground which I get, but not sure about the term behind. So what do I attach the Orange wire To?
Red wire has #10 fuse and is to be connected directly to positive battery terminal
Orange wire has #5 fuse behind???
Seats each have a switch that is off/low/high
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old October 17th, 2015, 11:31 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Switched 12volt, so that the heaters are not switched on with the ign off, switched voltage will be white wires on the loom.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old October 17th, 2015, 12:06 PM
BlackField's Avatar
BlackField
Oscar
D110
Does the kit have a wiring harness? Is there a relay? I'm assuming there is a relay:
Battery Power to 87
Lead to Heating element 30
IGN (behind wire??) to 86
Ground on 85
if that doesn't help, snap a pic of the harness and post it up.
Old October 17th, 2015, 03:47 PM
Jon_Winningham
Sterling M Archer
Photos
Old October 17th, 2015, 03:48 PM
Jon_Winningham
Sterling M Archer
Old October 17th, 2015, 07:39 PM
Jon_Winningham
Sterling M Archer
So any white wire in the fuse panel splice it to that?
Old October 17th, 2015, 09:20 PM
BlackField's Avatar
BlackField
Oscar
D110
Pretty much any wire that gets power when you switch the ignition on. It will only draw enough current to trigger the relay. It would be no different than finding the white wire bundle behind the dash.
Old October 17th, 2015, 09:33 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
This is how I did it, I used a volt meter and found that two of the four terminals in my relay panel in one relay plug that was left unused, were 12v with the ignition on. So I put spade connectors on the ends and plugged my seat heaters in there. Not sure if all D90s have this unused relay spot.
Old October 18th, 2015, 01:05 PM
Jon_Winningham
Sterling M Archer
Appreciate the help guys!
I'll plug it into the aux in the fuse panel
Getting my first multimeter
Love how these things turn us into me mechanics!
Old November 16th, 2015, 05:02 PM
Jon_Winningham
Sterling M Archer
Finally installed the heated seats...
But the red LED light stays on whether both of the switches are in off, on 1, and on 2 positions
the light does go out when the ignition is off and the seats heat up nicely.
should the LED always stay on?
electrical, heater
110 middle row seat reel install question usadventureracing Defender Technical Discussions 6 July 3rd, 2014 06:32 PM
Infant Seat middle seat install CDeWan Defender Technical Discussions 17 December 31st, 2012 04:14 PM
Rear bench seat install question flounder Defender Technical Discussions 3 September 29th, 2011 01:29 AM
Heated seat electrical question Campbell Defender Technical Discussions 19 October 31st, 2009 09:16 AM
Center seat install question brn24whl Defender Technical Discussions 7 October 9th, 2009 11:37 AM
