Seat Box Restoration - Defender Source
Old March 7th, 2016, 11:19 PM
RBBailey
RBBailey
1965 IIa
Is there any particular reason why the battery box under the seat should not be sealed as well as possible in the corners and such?
Project:
1965 IIa SWB
Old March 8th, 2016, 09:14 AM
Ventilation is important along with heat dissipation.
Old March 8th, 2016, 09:45 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Ventilation for what? Heat?
My seatbox doesnt have any working vents?!
Rent my
Old March 8th, 2016, 09:51 AM
The Dro
Dro
1988 Ninety
For the battery... Batteries release Hydrogen gas during charging
------ Follow up post added March 8th, 2016 09:58 AM ------
Should have added that Hydrogen is not toxic... but at high concentrations is a highly explosive gas.
Old March 8th, 2016, 10:04 AM
Think Hindenburg.
Old March 8th, 2016, 10:06 AM
Only if you are not using a sealed battery. Anyone that wants a sealed battery compartment should used sealed batteries.
Old March 8th, 2016, 10:15 AM
The Dro
Dro
1988 Ninety
Sealed batteries are not really "sealed". The caps have pressure valves.
------ Follow up post added March 8th, 2016 10:18 AM ------
Sealed batteries still produce Hydrogen... it's significantly less but still produce it.
Old March 8th, 2016, 10:20 AM
The valves only release in the event of catastrophic overcharge. They normally do not vent. as long as your charging system is working normally, there will be no venting.
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I use a dry cell battrey.
Of course, being a seatbox, there is also the methane gas consideration....
Rent my
Old March 8th, 2016, 10:23 AM
The Dro
Dro
1988 Ninety
True... But this is a Rover battery.
------ Follow up post added March 8th, 2016 10:24 AM ------
I'd be more worried about carbon monoxide
Old March 8th, 2016, 10:53 AM
Because LR electrical systems are known for their quality and reliability? SMH
Old March 8th, 2016, 11:44 AM
If the battery overcharged to the extent that the pressure relief valve blew, you have a lot more to worry about than a bit of hydrogen in the battery box.
Old March 8th, 2016, 11:58 AM
I don't think Hydrogen has been coming out of modern car batteries for decades, ever since the SLA was invented...like in the 70's. I guess there are lots of folks on this board in their 50's or 60's so they probably caught the tail end of the demise on the non-SLA.
That said, hydrogen can't be held in by much anyways due to the size of the atoms. Especially not a Defender seatbox, even if you caulked every seam with gallons of epoxy or silicone.
My opinion is that you don't want to seal anything on the ground floor of a Defender that well, especially the steel battery box. Anything sealed well holds water and the requisite ions, which in turn leads to corrosion.
My battery box has holes in the bottom anyways for the battery tie-down. Some dust gets in there, but that's easily hosed out, which has to be done regardless.
Old March 8th, 2016, 11:59 AM
The Dro
Dro
1988 Ninety
You clearly have no idea... it only takes 1-2 psi
Unless Canadian batteries are filled with Unicorn tears and made out of unobtainium metal plates
Old March 8th, 2016, 12:03 PM
I would explain, but you guys just want to randomly argue.... Do whatever you wish.
Old March 8th, 2016, 12:04 PM
Pass the popcorn!
The Dro
Dro
1988 Ninety
Originally Posted by Rocky View Post
Pass the popcorn!
Old March 8th, 2016, 12:08 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I believe in The Dro. He keeps the Metro running 😝
Jimmy Buffett
Old March 8th, 2016, 12:10 PM
As for gas check valves, do they actually exist in SLA car batteries? I thought they just depended on hydrogen permeability to let evolved hydrogen gas escape. If they have valves, I have no idea where they would be located as I've never seen one on the surface of a battery.
Old March 8th, 2016, 12:13 PM
Reading with a French accent isn't working for me any more. I'm out.
restoration, seat box
Heater Box Restoration / Info sonoronos Defender Technical Discussions 20 December 31st, 2016 12:08 AM
WTB Batter Boxy and Tool Box for Seat Box madcowdungbeetle Wanted 8 October 10th, 2014 07:41 AM
modified battery box and seat box Fearnofish Smaller Projects 4 March 28th, 2014 11:16 PM
(Replace that old ragged seat box trim) F/S "Brand New" Seat Box Insulator Trim Panel Buddie For Sale - Parts 5 April 30th, 2012 03:40 PM
r380 seat box vs. lt77 seat box? J.5 Defender Technical Discussions 1 July 23rd, 2009 05:17 AM
