Seat belt retract problem - Defender Source
Old February 2nd, 2005, 12:53 PM
surfd90
troy snyder
I have been through many seat belts now with the same problem.. The belt does not release from the housing... Is there some trick to this? Seems pretty simple yet i can find a solution...
Old February 2nd, 2005, 12:57 PM
jperakis
James Perakis
94 ST
did you take off the bottom bolt for some reason? or is just retracted an abnormal amount? if so there is a point for the belts where they will no longer release. I was told you just have to eat the cost and buy new.
Old February 2nd, 2005, 01:07 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Make sure the seat belt is attached correctly and in the upright position. It should release.
Worst case you may need to take the plastic cover off and release the locking mechinism by hand.
Old February 2nd, 2005, 03:00 PM
94d90
dennis mcguinn
1994 defender
spray the inside with wd40
ac
Rear Seat Belt Brackets zed111 Defender Technical Discussions 11 August 6th, 2007 02:45 PM
Need Rear Seat Belt Receiver for D-90 ST YellowD90 Wanted 0 November 5th, 2005 11:54 PM
Seat belt! TwisteD90 Wanted 3 July 8th, 2005 08:03 PM
Lap seat belt for the rear - flip up seat paulb Defender Technical Discussions 2 January 27th, 2005 03:43 PM
Lap Seat belt for a Trakker fold up paulb Wanted 0 January 24th, 2005 11:56 AM
