Seat Belt question - Defender Source
Old May 31st, 2014, 05:38 PM
jt2127's Avatar
jt2127
John Thomson
2010 Sport & 2013 LR4
Seat Belt question
An someone point me to the explanation for how to to release a retracted seat belt? I've been searching and can't find it.
Or a quick explanation. Either way. Got one I can't install (shoulder belt) because it's retracted too far.
Thanks.
Old May 31st, 2014, 05:42 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Not sure if it's the right way... But I removed the outer cover to actuate (release) the catch. Worked for me
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old May 31st, 2014, 05:55 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
yes but you must be VERY careful if you try this as it is all plastic. the principle of the retractor that is...what allows it to function is based on an internal pre tension mechanism and the angle that it is operating on.
So the angle of the dangle...
in this video when he takes the outer cover off the little silver ball is what lets the mechanism operate. If it's not allowed to move as intended it will seem as if the mechanism has failed.
Old May 31st, 2014, 08:07 PM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
I tried this and f'ed it up, I had the same problem and was told to bolt it in place or put it in a vice making sure it was straight up and that did the trick. Good luck,
Old May 31st, 2014, 09:00 PM
Just unbolt the top hanger (by the shoulder) so it can retract a little further, and then it releases. It sounds like you might have a disco Y piece, and if so, the only permanent solution is a longer Y, or make a short strap to lower the top hanger. There is a thread somewhere here showing how I did mine.
Thanks.
Originally Posted by pendy
I'm here for the D's
Old May 31st, 2014, 10:55 PM
jt2127's Avatar
jt2127
John Thomson
Appreciate the quick help, guys. Got it installed.
Old May 31st, 2014, 11:07 PM
Not a new issue if you look around. Try this
http://www.defendersource.com/forum/...ad.php?t=46263
Rear Seat Belt Y-Belt from D1 tebby For Sale - Parts 4 May 27th, 2014 12:42 PM
Seat Belt Question mpsteil Defender Technical Discussions 0 June 16th, 2009 08:41 PM
Seat Belt Question mpsteil Defender Technical Discussions 1 November 22nd, 2008 05:26 PM
95 D90 Seat Belt & anchor for bench seat grinch79 Wanted 0 April 9th, 2007 03:12 PM
Lap seat belt for the rear - flip up seat paulb Defender Technical Discussions 2 January 27th, 2005 03:43 PM
