Seat belt install - Defender Source
Old January 1st, 2016, 03:35 PM
atpick's Avatar
atpick
Andy
1990 110
Seat belt install
Gonna pull my hair out I swear, I got all the bits installed for my new seat belts and when I got the first one in, it wouldn't unlock. The other side won't unlock either, so I took the left side off to try to unlock it and it rewound all the way back into the reel and is stuck..... Is there a certain way you have to release these things?? It the exmoor trim 4 point inertia reel.
Old January 1st, 2016, 04:26 PM
Matt_110's Avatar
Matt_110
Matt
110
I ran into the same thing a few years ago and had to disassemble them to fix it. I didn't read the instructions and think I removed a tab or something in the wrong order.
1987 110, 2.8TGV, ZF Auto
Old January 1st, 2016, 04:28 PM
Yes. The seat belt reels will lock unless the reel is aligned precisely in the installed position.
Gravity is what is causing the belt reel to lock.
Place the reel in the exact installed orientation, preferably on the vehicle, or clamped in a vise.
The reel should then unlock automatically. Just gently tug on the strap and gently tap the reel if it does not smoothly release.
You should never have to disassemble the reel for any reason.
Old January 1st, 2016, 04:31 PM
Matt_110's Avatar
Matt_110
Matt
110
Wish I would've known that. Good luck!
Old January 1st, 2016, 04:41 PM
atpick's Avatar
atpick
Andy
1990 110
Yes. The seat belt reels will lock unless the reel is aligned precisely in the installed position. Gravity is what is causing the belt reel to lock. Place the reel in the exact installed orientation, preferably on the vehicle, or clamped in a vise. The reel should then unlock automatically. Just gently tug on the strap and gently tap the reel if it does not smoothly release. You should never have to disassemble the reel for any reason.
What if it has rewound all the way into the reel?
Old January 1st, 2016, 05:01 PM
Although it appears that letting the belt rewind back into the reel is what causes the belt to release (as is consistent with casual experience. Belt locked while driving? Let it reel back a bit, then pull it out), that is not the actual reality of the mechanism.
The actual reality is that gravity unlocks the mechanism, and letting the belt reel in is not what unlocks the mechanism (as would normally be deduced.)
Old January 1st, 2016, 05:51 PM
Search toilet here and you should find my instructions. I know. Weird but it works.
Found it.
http://www.defendersource.com/forum/...all-30784.html
Old January 2nd, 2016, 04:09 AM
atpick's Avatar
atpick
Andy
1990 110
Remounted straight up and down, no issues, works perfect, thanks guys.
Rear Seat Belt Y-Belt from D1 tebby For Sale - Parts 4 May 27th, 2014 12:42 PM
Seat belt install help jt2127 Defender Technical Discussions 4 May 4th, 2014 07:30 PM
D110 middle seat, seat belt install questions akrockhound Smaller Projects 0 December 17th, 2013 07:58 PM
Rear seat belt install apierce Defender Technical Discussions 9 May 31st, 2011 04:05 PM
Lap seat belt for the rear - flip up seat paulb Defender Technical Discussions 2 January 27th, 2005 03:43 PM
