Seat Belt Buckles - Defender Source
Old March 6th, 2016, 11:38 PM
Seat Belt Buckles
Audible seat belt buckles? Inaudible seat belt buckles? My truck has front audible buckles that don't fit correctly due to their or the seat placement. They need to be reversed but there isn't room. The red push button is in the inside, not the outside when buckled. What is the advantage/disadvantage to each?
Old March 6th, 2016, 11:52 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Picture? They are probably just reversed?
Old March 6th, 2016, 11:54 PM
There isn't enough room to reverse them, I tried every which way. I'll get pix up tomorrow.
Old March 6th, 2016, 11:56 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Can you swap them side to side? Left to right? Literally unbolt them and switch them in the factory mounts, should be a retained 17mm. Shouldn't take more then five minutes.
Old March 7th, 2016, 12:02 AM
I tried. Photo's in the morning. Thanks for your reply Brian.
Old March 7th, 2016, 09:26 AM
Swapped them and as you can see the buckle is in the way of the seat moving and has to be installed on a weird angle. The drivers side is even worse.
Old March 7th, 2016, 12:53 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I've honestly never seen one like that? I'll post a pic of the stock ones I was thinking of.
Old March 7th, 2016, 12:58 PM
jafir's Avatar
jafir
Jafir Elkurd
I think the audible would be the ones that have the warning buzzer or light on the dash if you don't have your seat belt buckled. So there is probably an electrical connector on the buckle.
But I've been wrong when guessing on defender stuff in the past.
Old March 7th, 2016, 01:14 PM
I don't see any wiring on the ones I have but I'm guessing you may be right.
Old March 7th, 2016, 02:52 PM
wanabewheelin's Avatar
wanabewheelin
Michael Sword
1989 110 200TDI, RHD
What year truck are they on? Those appear to be for Defenders 2007+
SEAT BELT BUCKLE ASSY RHF DEF 2007+, EVL501080PMA - Rovers North - Classic Land Rover Parts
When I upgraded mine last year believe I picked up some similar to these, I needed rear ones for the new Puma style seats (middle row) and upgraded the fronts also as they were sticking.
Land Rover Seat Belt- Defender 90" 2 Door L/H Reel and Buckle | eBay
Could be incorrect on this, there are several other types out there.
http://www.landroverworkshop.com/dia...-front_53633#3 diagram of the audible and non-audible belts
------ Follow up post added March 7th, 2016 02:59 PM ------
This appears to be a center seat belt . . . Land Rover Defender 52 110 TD5 Centre Front Seat Belt | eBay
upon closer review . . .
Old March 7th, 2016, 04:20 PM
That's exactly what they are. Anybody wanna trade?
Rear Seat belts and buckles for a 90 ST with a bench seat toddw Wanted 6 February 23rd, 2016 07:14 AM
Rear Seat Belt Y-Belt from D1 tebby For Sale - Parts 4 May 27th, 2014 12:42 PM
Exmoor Jump Seat Seat Belt bjp For Sale - Parts 0 October 12th, 2008 07:08 PM
95 D90 Seat Belt & anchor for bench seat grinch79 Wanted 0 April 9th, 2007 03:12 PM
Lap seat belt for the rear - flip up seat paulb Defender Technical Discussions 2 January 27th, 2005 03:43 PM
