Seat Belt Anchor? - Defender Source
Old February 25th, 2016, 01:32 AM
RBBailey
RBBailey
1965 IIa
Seat Belt Anchor?
Can someone show me the proper way to attach the upper part of a seat belt in a Defender 110? Pics?
One of mine is a home made piece....
The other is bolted directly to the body, bolt going through to outside.
Project:
1965 IIa SWB
Old February 25th, 2016, 02:06 AM
KSARover110's Avatar
KSARover110
Dan
1983 Rover 110
Don't have actual pic of mine but this shows the bolt hole locations to to upper pillar
Old February 25th, 2016, 02:16 AM
RBBailey
RBBailey
1965 IIa
Doesn't look right. I need the front driver/passenger upper anchors.
Project:
1965 IIa SWB
Old February 25th, 2016, 02:36 AM
KSARover110
Dan
1983 Rover 110
Originally Posted by RBBailey View Post
Doesn't look right. I need the front driver/passenger upper anchors. Thanks,
Ok right this is for the second row
Old February 25th, 2016, 07:45 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You should have a connection point on you "B" pillar. It is threaded for the seat belt bolt, 10mm or so. right in the metal.
Land Rover 110
Old February 25th, 2016, 09:00 AM
98 HOO's Avatar
98 HOO
Josh Smith
1960 Series 2a/D90 Hybrid
Assuming it is a hard top, I have a pair of the anchors for sale...
Hartop Upper Seatbelt Brackets - Defender Source
PM me if they are something you are interested in.
Old February 25th, 2016, 08:14 PM
Capt Milks's Avatar
Capt Milks
Is your truck a four door or two? The above brackets should work if it is the two door.
Land Rover 110
Old February 27th, 2016, 03:21 AM
RBBailey
RBBailey
1965 IIa
Thanks for replies. I had already asked about those anchors you have for sale, but forgot about them! I'll confirm if they would work.
It is a four-door 1988 RoW.
Project:
1965 IIa SWB
Old February 27th, 2016, 05:55 AM
Capt Milks's Avatar
Capt Milks
Should be on the "B" pillar then. Do you have trim on the upper piece of the pillar?
Land Rover 110
Seat belt anchor brackets Rocky Defender Technical Discussions 1 June 10th, 2014 07:22 PM
4 point seat belt anchor grnrvrs Defender Technical Discussions 3 July 9th, 2012 02:07 PM
95 D90 Seat Belt & anchor for bench seat grinch79 Wanted 0 April 9th, 2007 03:12 PM
?? tub anchor point - needed?? paulb Defender Technical Discussions 3 June 23rd, 2005 01:02 PM
rail system hooks & anchor point mounts paulb Defender Technical Discussions 2 November 24th, 2003 01:16 PM
