seat beat help - Defender Source
Old June 15th, 2013, 11:47 PM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
seat beat help
What is the trick to get the seat belt to extent or roll out. I unbolted it from the floor and it retracted. Now I can't get it to extend so I can rebolt it to the floor. I feel stupid. Please help.
Old June 15th, 2013, 11:50 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Bolt it back down! Sounds crazy, but try it.
Old June 16th, 2013, 01:42 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
it has a simple internal mechanism that is designed to release when it's at the right angle. It should retract when you bolt it back in in its original angle.
Old June 16th, 2013, 07:49 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Hold it at a level angle and it will release
Old June 16th, 2013, 12:10 PM
Lemonhead
TB
1997 D90 SW
Yep - I was freaked out when my new belts did the same. Bolt 'em in and they work correctly.
Old June 16th, 2013, 12:33 PM
Here you go:
Originally Posted by rijosho View Post
I just installed new belts this weekend for my bench seat as both of the rollers on the old ones broke and were basically useless.
With seatbelts, when you pull them very fast (simulate crash) the spool moves forward a little which forces a metal w-shaped piece above the spool to "lock" into the belt that is exiting the mechanism, stopping anymore forward movement of a passenger. When the belts are fully rolled up/spooled, it has the same effect on that metal spring piece, as it pushes upward on it which lock belt from exiting any further.
What you have to do is unroll the belt spool from the bottom, as the actual spool is not locked, but the belt exiting the seatbelt mechanism is. Once you get about 2-3 feet unspooled, the metal piece should loosen off of the belt and it should now work properly. Don't let the belt roll all the way back in and this should not happen again.
Old June 16th, 2013, 12:41 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
They will also need to retract slightly to release.
They will also need to retract slightly to release once bolted in place.
I often just clamp them in a vice in the correct position then retract slightly, then they come free and roll out. We have some of the little metal spring clamps used to hold loose papers together and put these on the belt with 2 small pieces of cardboard to prevent the belts from retracting all the way.
RDavisinVA
Old June 16th, 2013, 04:04 PM
CavemanDiesel
Eric Smirh
1985 D90
Once again you guys come thru, thanks.
Baby Car Seat QUESTION Flagg Misc. Chit-Chat 5 August 4th, 2007 06:39 PM
Front Seat Covers Flagg Defender Technical Discussions 8 February 13th, 2006 07:45 AM
Rear Bench Seat + hardware Chaucer For Sale - Parts 8 September 29th, 2005 12:16 AM
D-90 3rd seat up front ?Possible - How? paulb Defender Technical Discussions 17 October 28th, 2004 07:26 PM
beat up broken trashed jump seat dnewman9 Wanted 0 June 27th, 2004 12:38 PM
