Searching idle, replaced stepper now what? - Defender Source
Old July 15th, 2006, 02:39 PM
btate
Bryan Tate
d90
94 d90, the idle was searching up and down and would cut off at a stop.
I did the Napa Stepper motor/idle control valve swap, and I was putting in a dual optima, so the battery was disconnected for about 10 minutes.
The idle stills hunts, previous posts said to "wait awhile" or "reset the computer"
How long is awhile, and is it good to leave the car idling for it to figure it out, or drive it.
Also what's the procedure for resetting the 94 computer??
Any other things to try or do I just need to be patient and let it heal itself??
Old July 15th, 2006, 04:06 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Have you updated your ignition module?
Old July 15th, 2006, 04:08 PM
btate
Bryan Tate
d90
no,
Please elaborate....at this point I am ready to replace about anything...just to have less things to worry with...
Old July 15th, 2006, 04:30 PM
Abrooks's Avatar
Abrooks
Tony Brooks
94s for some reason (and just defenders, not 3.9RRCs for some reason) eat the original ignition module that was mounted to the side of the distributor. There's a factory retrofit -- stc 1856 if I remember -- that repositions it next to the coil. As its dying it can cause strange running issues like a hunting idle, intermittant cutoff, etc. I spent a lot of time and $ trying to diagnose it on mine, turned out a bum replacement alternator was frying them. In any case, you can try the factory reposition kit or make your own using a replacement module and a home-made loom. The kit supplies a little bracket that would be dead simple to make yourself. First step is to check and see if you have original module.
Feel free to PM or email with any questions.
Tony
ac, idle
Anyone use a different idle air control valve (stepper motor)? Baja 90 Defender Technical Discussions 12 October 16th, 2009 01:21 AM
Idle Control Valve (idle stepper motor) fleabus For Sale - Parts 3 June 28th, 2009 12:13 AM
Stepper Motor- idle air control 1995 Scott 9835 Defender Technical Discussions 3 October 23rd, 2006 02:20 PM
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
The latest show-stopper: dies at idle, only runs above 2K rpm jaherring Defender Technical Discussions 34 December 23rd, 2004 07:05 PM
