Sealing foam around 300tdi intercooler - Defender Source
Old April 26th, 2014, 12:20 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
What have you guys used for replacing the foam that seals the gap between the intercooler and radiator?
I have some left of Dynamat from back in the day, but in think its only recommended to 200 degrees F.
Thanks!
Pete
Old April 26th, 2014, 12:48 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I used some AC surround sealing foam from Homer depot seems to be holding, I had some left over from a job. also used it to seal the sides of the rad&innercooler to the body panels
But I am sure somebody will chime in he doesn't use anything or a far superior product
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 28th, 2014, 08:57 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I used a rubber infused foam insulation that you can buy at the big box stores. It even had the sticky on the back. Has held up for years.
300tdi, tdi
Has anyone tried the Terrafirma Foam Air filters for a 300tdi? Manimal Defender Technical Discussions 19 April 27th, 2017 07:08 PM
Threads on sealing up D90 for warmth? Gkase Defender Technical Discussions 44 December 1st, 2011 12:26 PM
Sealing leaks in a 5 door 110 Chris Velardi Defender Technical Discussions 3 October 4th, 2010 10:35 PM
Sealing Borla Y-Pipe Flange cellulararrest Defender Technical Discussions 6 October 31st, 2009 08:31 PM
Sealing Rear Wheel Well Bolt Holes Boone90 Defender Technical Discussions 10 February 18th, 2007 01:30 PM
