Sealing Borla Y-Pipe Flange - Defender Source
Old October 27th, 2009, 10:32 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
How hot do you think that flange behind the cats gets? JB Weld is rated up to 500 degrees. I can't imagine it gets hotter than that...
Do you think I'd be ok JB Welding that flange together? I seem to think so, but want a second opinion so I don't smell like burning JB on the highway...
I just need to pass inspection... They decided after 3 years they didn't want to pass it with that flange leaking.
Old October 27th, 2009, 10:49 PM
i used regular plumbers epoxy putty on my RRC in the same spot. it stank something fierce. try one that says it is rated for manifolds or exhausts from your FLAPS
Old October 27th, 2009, 11:15 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
prob better to use a manifold patch type of compound...
Old October 28th, 2009, 01:32 AM
They have a product for this exact application and it is removable enough unlike JB weld. Go to auto parts store.
Old October 28th, 2009, 08:26 AM
cellulararrest
Chris Snyder
Perfect. That was another potential problem with JB Weld. I'd never get it off! Any idea what it's called? Or I'll just ask around.
Old October 31st, 2009, 08:08 PM
cellulararrest
Chris Snyder
Found some "Exhaust sealer" at autozone. It worked perfectly. Thanks for the tip.
Old October 31st, 2009, 08:31 PM
No problem.
borla
Borla Flange cellulararrest Defender Technical Discussions 0 April 18th, 2009 07:47 PM
Y Pipe Flange 97D90 Wanted 4 November 29th, 2007 01:19 AM
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
Exhaust Pipe Removal Question Rob Defender Technical Discussions 0 September 17th, 2004 02:27 PM
» Defender Registry
Stu II
Greenbull
90
clb1994
Add your Defender
