Sealed battery? - Defender Source
Old December 18th, 2003, 02:37 PM
OCD90's Avatar
OCD90
Torrence
1997 Hardtop
Sealed battery?
While fiddling with the electrical the other day, I was under the seat looing at my battery. Has anyone used an RV battery (I think they're called sealed cell)? I'd like to seal off that box beneath my seat and insulate it. I know it contributes a lot of noise and cold air to the car. I figured I could get around the need to ventilate by using an RV battery, then sealing the box off from the elements.
Thoughts?
Old December 18th, 2003, 10:13 PM
Why not get one of those "boxes" like they use for batteries in the marine venue?
Old December 19th, 2003, 05:52 PM
Optima batteries are sealed.
Old December 22nd, 2003, 01:26 PM
OCD90's Avatar
OCD90
Torrence
1997 Hardtop
So, you think getting a sealed battery, like the optima (or similar) would be a good/safe way to allow me to seal off the battery box below the driver's seat?
I can just feel the air rush in, and hear a good amount of road noise that I'd like to eliminate.
Old December 22nd, 2003, 01:43 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
It depends on what you mean by sealing off. I closed up all the holes in my box with liquid aluminum and then coated the inside of the box with liquid rubber. Then I put silicon where the wires come in and carpet on the bottom of a custom made lid. I can still get access to the dual optimas easily but the noise is cut. If you mean seal as in you can never get back in there, it is not a good idea as every battery needs occasional maintenance.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
battery
Battery Light/Tachometer Intermittant markurski Defender Technical Discussions 9 June 21st, 2009 09:18 PM
Battery Compartment under seat Flagg Defender Technical Discussions 11 May 15th, 2007 11:38 AM
Dead Battery...maybe? Antonios Defender Technical Discussions 11 November 17th, 2004 10:41 AM
