Seal on the Driveshaft - Defender Source
Old May 14th, 2004, 08:01 AM
dbwitt's Avatar
dbwitt
Darrin Witt
1995 Defender 90
THE SEAL (s) ON THE
D RIVESHAFT U-JOINTS ARE LETTING GREASE SLIP BY -----Original Message---
This is the message that the dealship put on my Defender after it was serviced. Anybody know if this is a big deal? Can I fix it myself? I am a so so mechanic. I know where the driveshaft is.
Old May 14th, 2004, 08:09 AM
WHAT!
When you fill U-joints you have to force out the old grease with new grease! This is done by forcing the grease through the seals! What a load of CRAP! If your U-Joints start going bad you will feel it. Then buy some from George at Rovers Down South and replace them yourself, they are easy to do. If you go to the dealer they will charge over $100 per U-Joint + installation costs. My friend just had all the UJs replace at the dealer on his Disco and it cost $1000.
Old May 14th, 2004, 08:20 AM
Berty's Avatar
Berty
Brett Hurrell
D90 Hardtop 300Tdi
It probably took those twats at the dealer around 8 hours to change out 4 joints.
I guess for a thousand bucks they at least cleaned the truck for him!
Sniff my Diff ;)
Old May 14th, 2004, 08:29 AM
me dealership. Now you know why I want a Machine Gun mounted on the top of my 90. Ya they cleaned it and he still had vibrations, later he found out they were from a bad motor mount.
If you need more info on changing your UJs let me know,
Old May 14th, 2004, 08:41 AM
Berty's Avatar
Berty
Brett Hurrell
D90 Hardtop 300Tdi
Ah, pressing in new uj's. A baptism of fire for a virgin Land Rover mechanic.
Get yourself a pack of bandaids for your poor knuckles Darrin
Seriously, it's not that bad as long as you've got a Vice. You'll also need a 9/16 ring spanner or even better a narrow long reach socket plus some circlip pliers. Oh & a big f****in hammer
Sniff my Diff ;)
Old May 14th, 2004, 09:52 AM
dbwitt's Avatar
dbwitt
Darrin Witt
1995 Defender 90
A appreciate the help!
Old May 14th, 2004, 11:46 AM
WCURoverD90's Avatar
WCURoverD90
Jason Habbal
1997 Defender 90 #1104
Fuck the dealerships.....There not worth a damn....Just trying to rip people off....The way I do it, is to learn how to do everything myself so I don't have to take it to those bastards....
"tell them to phucough"
Land Rover-The Best 4x4xFar
Old May 14th, 2004, 11:50 AM
Berty's Avatar
Berty
Brett Hurrell
D90 Hardtop 300Tdi
I take it you're not overly impressed with your main dealer experience then Jason?
Sniff my Diff ;)
Old May 14th, 2004, 12:18 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Hey, if you don't have good snap ring pliers now is the time to spend the doe!! I just did my u j's on my disco & broke my Matco's half way threw the job!
drives
Seal at axle tube/swivel ball snuffer Defender Technical Discussions 8 February 7th, 2011 05:06 PM
Driveshaft replacement Doug Defender Technical Discussions 39 July 9th, 2008 11:24 AM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
Driveshaft Issues Continue...?? P1CR Defender Technical Discussions 9 July 22nd, 2004 09:12 PM
Stripped nuts on the driveshaft... dmarchand Defender Technical Discussions 13 November 18th, 2003 09:41 PM
