Seal between bulkhead and lower dash - Defender Source
Old April 16th, 2011, 02:19 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I cut the bulkhead to match the opening of the heater and need to make a seal between the lower dash and the bulkhead as the factory seal will no longer be the correct size.
What is the proper type of material to use between the bulkhead and the lower dash?
Ace Hardware has some different types of weather stripping seals that come in a roll, one is made of closed cell rubber and the other made of closed cell foam will either of these work? If so how thick is the stock gasket?
Or would a roll of the stuff that you use to seal the floor boards to the bulkhead be preferred in this location?
MRC8626
http://www.lrseries.com/shop/product...EAL-STRIP.html
Old April 18th, 2011, 12:29 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Anyone?
Old April 18th, 2011, 12:49 PM
I so need to do this job too! Was it obvious where to cut? I would think standard automotive weatherstrip would suffice.
Old April 18th, 2011, 01:10 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I used adhesive backed closed cell rubber from ACE.
Old April 18th, 2011, 01:35 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I was starting with a new bulkhead so there were no marks where the old heater would have been so I just put some chalk line powder on the heater and put it in place to give an outline of where to cut.
Easy Mod to do and you can leave a little extra if you are worried about cutting too much.
Kevin, thanks for confirming that, I figured that it would be ok.
Any recommendation on thickness?
Old April 19th, 2011, 01:14 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Can you hold the lower dash in place to see if there is much of a gap? I know the stock seal is pretty thin foam. I'd think 3/16 would compress enough to fill the gap without causing any fit issues.
Tony
1984 110 "Smokey" (sold)
Old April 19th, 2011, 09:10 AM
I'm going to do this project this weekend.
Old April 19th, 2011, 09:57 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
I know on the S3 lower dash there are two(?) holes at the ends of the lowest portion of the dash, noticed them along the back edge that goes against the bulkhead. I presume this is for drainage for any condensation/water intrusion that can occur.
Old April 19th, 2011, 11:39 AM
what he said x2 get the fairly thin stuff
dash
Bulkhead Welding v New grnrvrs Defender Technical Discussions 10 April 23rd, 2010 02:45 PM
Bulkhead LH footwell repair panel? turbodave Defender Technical Discussions 1 August 22nd, 2008 03:03 PM
Project: Lucas must die Buckon37s Misc. Chit-Chat 22 September 26th, 2007 11:45 PM
spring cleaning- D90 parts Chris Cox For Sale - Parts 13 April 4th, 2005 01:51 AM
