Seal at axle tube/swivel ball - Defender Source
Old August 19th, 2005, 01:06 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
I remember some time back seeing a thread about running with/without the oil seal that seperates the swivel ball from the diff.
When I broke a stub axle recently it shredded the end of the axle spindle making it impossible to remove the hub nuts so I could make a trail repair. I was forced to drive back to the trailhead with lots of metal grinding around in the CV, wheel bearings etc.
The oil seal kept the metal out of the ARB. $$$
Old September 2nd, 2005, 11:51 PM
You know I have thought the same thing a couple of times Randy. Around here mud finds it's way into the wheel bearings all the time, it's no big deal to change out wheel bearings but I would hate to have to change the diff bearings or the inner bearing on the CV eerytime the bearings got muddy., or worse like you said to do damage to the diff itself.
Old February 5th, 2011, 07:24 AM
Ive read a lot about this FTC3511, is this only in the front stub or in the rear stub also? This is seriously becoming a tad bit frustrating.
Old February 5th, 2011, 10:33 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Are you thinking of the RTC3511 double lip hub seal?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 5th, 2011, 08:19 PM
IDK, Ive gotten educated on this entire setup after about an hour here and on the Dweb. That seal is for the HD axles,
Old February 5th, 2011, 11:24 PM
Antichrist's Avatar
Antichrist
Tom Rowe
I'm not sure what seal you're talking about then. FTC3511 is a housing. RTC3511 is a hub seal for D90's, RRC, D1's....
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 6th, 2011, 07:53 AM
the seal located in the stub axle.
Old February 7th, 2011, 04:46 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
RTC3511 hub seal, use it on the front and the rear, be sure to put a little grease on the lips before installing the hub.
Keith
Big, Red and ... aaa Red..
Old February 7th, 2011, 05:06 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The inner hub seal will work on both the HD and stock axles. The raised part of the axle is what the seal rides on. I have always installed new ones even though the fronts are a pain to get to. I have heard of guys running with out them but you point makes sense. I guess that is one reason why Rover does it that way.
Land Rover 110
axle
swivel ball seal parts hotroddef90 Defender Technical Discussions 19 February 9th, 2014 03:26 PM
Stubbed... stub axle bearings and seal thewap Defender Technical Discussions 2 June 29th, 2006 08:07 AM
Interesting swivel ball problem dameek Defender Technical Discussions 1 July 24th, 2005 01:18 AM
Temp fix for leaky swivel ball seal? solihul Defender Technical Discussions 5 July 2nd, 2005 05:47 PM
Anyone do this? Bowtracer Defender Technical Discussions 13 March 18th, 2005 02:32 AM
