Seafoam - Defender Source
Old April 17th, 2004, 12:19 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Seafoam
Found out this morning that Seafoam has more uses than I originally thought. Pulled off the vacuum line to the brake booster, and began pouring it in. Instant steam inside the engine compartment. Finally found that exhaust leak I though I had been hearing. The seafoam actually wets the area that is leaking, so it is very easy to detect. I know this is not a great discovery, but it may help some other people out there with an annoying exhaust leak that is difficult to find.
Old April 18th, 2004, 12:23 AM
You know when I ran Seafoam through my 90 there was steam coming from the PS of the engine. It was dark so I could not see where it was coming from, I will have to run it through again.
Old April 19th, 2004, 12:01 AM
cbkearney's Avatar
cbkearney
Chris Kearney
Pile of Parts
I would be wary of this product. I know a lot of people have had good experience with Seafoam, but a good friend of mine had a rough idling Range Rover and I mentioned what you guys said about Seafoam and its effectiveness. He tried it and a couple of days later blew a head gasket on the Mass Pike. It could be completely unrelated, but it seems a bit suspect. Just an FYI.
Chris Kearney
CB Kearney Fine Woodworking
250 Canal St
Lawrence, MA 01840
781.576.9171
Old April 19th, 2004, 12:23 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
I have to agree with Chris. Seems like solving the symptoms and not the problem. Just sounds problematic to me...
EwS
Old April 19th, 2004, 07:49 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
I have a 4.0 with 172,000 miles that has never had a valve job. It needs one, but I will probably replace the engine before I pay for a valve job. Truck ran noticeably better after using the seafoam a couple of times. I seriously doubt this stuff would cause a head gasket to blow.
How in the world have I spent this much money and still don't have a running vehicle?
Old April 19th, 2004, 08:32 PM
pcarey's Avatar
pcarey
Peter Carey
'93 NAS Defender 110 #322
Same here. 170+K on a 3.9 that was idling rough. Checked hoses and stepper. Poured in some seafoam and it's evened out, mostly. Not perfect, but it will get me another few miles.
pwc
pwc
Old September 11th, 2004, 07:29 PM
jonjon
jon k
1995 defender 90 green
Cool seafoam where do I put it
I have a 95 d90 and I want to run some seafoam through it. It says to pour some in the throttle body, how do I get to it. I don't know where it is. It also says to pour some in the crankcase. Do I just pour it where the oil goes? As you can see I am far from a mechanic. Any help would be great.
thanks, Jon
Old September 11th, 2004, 09:41 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Jon, The way I read the instructions, since it's petroleum based, you can add to both the oil and to the fuel (either in the tank or into the throttle body). I removed the vacuum line from the brake master cylinder. Give it a little tug and it will pull out. No need to take off the clamp to remove the hose, just pull the plastic fitting out of the rubber grommet on the master cylinder. There's suction on that line. Put that line at the top of the can and, with the motor running, the Sea Foam will be sucked into the manifold. Careful not to stick it too far into the sea foam, or it'll flood the engine and the motor will die. I put 1/3 of the can into the throttle and the remainder into the fuel tank.
No one in their right mind would pay me to be a mechanic either, and if for some reason you trust me and the guys here say I was wrong... well, we're both hosed.
Old September 12th, 2004, 09:38 AM
jonjon
jon k
Ken,
Thanks It worked. I did flood the engine but after I got it started it ran great.
Thanks again,
Jon
Old September 12th, 2004, 10:33 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Merging the 2 Seafoam threads and moving it to Tech as its a good little tidbit.
Chris von C
[/size]
Old September 12th, 2004, 11:21 AM
John it does say to poor some in the crank case, but it also says to do an oil change within an hour of running after pooring it in.
Old September 13th, 2004, 12:59 PM
zed111's Avatar
zed111
Zed
1994/Defender 90
Hi Mike,
I poured some into the crank case on Saturday to free a sticky lifter, I didn't read anywhere on the can or the web site that they recommend changing the oil after an hour? Where did you see this?
http://www.seafoamsales.com/motorTuneUpTechGas.htm
I went from Dino to synthetic and now have a sticky lifter, so far the Seafoam has not fixed it but I only ran it for about 10 minutes after using it in the crank case.
Zed
PS. I also had steam come from the PS of my engine
Old September 13th, 2004, 04:10 PM
Hmmm, I'll have to check the can I thought I saw that on it.
Old September 13th, 2004, 10:05 PM
jonjon
jon k
Well I got the seafoam in the system. I changed the oil, but it was a day after I put the seafoam in. What a mess I made. You know I read the owners manuel and it does say to put the new oil in before you take the filter off. I could not undersand how you could do that without all the new oil spilling out. I just did it the regular way took the plug out then took the filter off then put the oil in. I realized after I made a mistake. But luckily the oil light did not come on and no wierd noises. I suck at doing these kind of things.
Misfire / Very poor fuel economy Jerry Defender Technical Discussions 14 November 13th, 2017 10:24 PM
Engine Cleaning cbass Defender Technical Discussions 1 September 4th, 2004 08:45 PM
