Sea Foam burnt up seals? - Defender Source
Old January 14th, 2007, 06:05 PM
hlamar's Avatar
hlamar
Heston LaMar
97 NAS D90 ST #1789
When I first got my 97 NAS D90 a little less than a year ago, it was running fine. It had about 79K miles on it. Not knowing the full service history of the vehicle, I began prophylactically changing all the fluids. When I changed the oil the first time, at a friend's suggestion, I added some Sea Foam to the oil(http://www.seafoamsales.com/motorTuneUpTechGas.htm). Within a few days after, it seemed the truck starts running rich and having the "smelly exhaust" problem recently referenced in Hutch Craig's recent post in this forum. I also started noticing oil leaks all around the oil pan -- it had been a little moist before but never dripped to the floor. Some of the oil leak is right by the catalyst converters (any danger of fire here?). Could Sea Foam eat up the seals like this, maybe even cause oil/gas mix in the engine -- causing the "rich" smell (i.e., burning oil)?
How much of a pain in the arse is it to drop an oil pan in a 97 NAS D90? Any help comments, experience, etc. is much appreciated!
Heston
Heston
Old January 14th, 2007, 06:39 PM
Tim Scully's Avatar
Tim Scully
Tim Scully
95 D90 SW/ 95 RR LWB
Heston,
How much sea foam did you mix into the oil? I have heard of people doing that but have never experimented with it myself. I would tend to think that it would take longer than a week to deterorate the seals in the engine and this is probably just a coincidence. As for the smell I guess the sea foam could be more combustable and thin the oil out causing it to smell differently. The smell is more than likely just the oil hitting the exhaust as it drips off of the rear of the engine.
The oil pan isn't terribly difficult but can be a messy job. I always use the "RightStuff" sealant instead of permatex or other sealants. It can be hard to get the pan off sometimes but if it is leaking a great deal using a small pry bar should get it right off. While you are in there be sure to make sure the pick up doesnt have a lot of debris in it. A lot of the oil pans were resealed by the dealers and the techs were known to use too much of the sealant causing the pickup tube to be partially blocked. You need to drop the sway bar if you still have on the get the pan out. Just remove the four bolts on the sway bar rubber mounts and the pan comes out behind the fron axle.
Old January 14th, 2007, 07:36 PM
hlamar's Avatar
hlamar
Heston LaMar
97 NAS D90 ST #1789
Thanks for the reply Tim. I actually drained the oil w/ the Sea Foam about 100 miles ago and replaced the oil and filter but same smell & leaks...
Heston
Old January 14th, 2007, 09:55 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Its just coincidence. If the oil pan is leaking. Remove it and reseal it. Not the biggest job to tackle.
Rislone is a much better way to help clean sludge from an engine.
JP
legend in my own mind
Old January 14th, 2007, 10:37 PM
Monkeyboy
Guest
Posts: n/a
Or just change it more often and drive the crap outta it
I've never used any of the cleaner stuff except Techron in the gas .... and Rotella oil ... why would I need the Seafoam / Rislone again?
Good to see you can type, Jimmy
"Italian Tune-up"
Old January 15th, 2007, 05:32 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I removed a Disco oil pan last year with in excess of 280,000 on the clock. There was an indention in the buildup of sludge at the bottom of the oilpan. Over an inch deep depression leading to the Drainplug.
Seen this over the years on high mileage RRC also, but this was something extra special. These engine likes to run dirty, even when maintained. A little rislone every now and again is my answer to this. Besides it pours out blue, so it must be cool.
JP
Old January 15th, 2007, 09:02 PM
Monkeyboy
Guest
Posts: n/a
Ooooo, blue!? I'm sold now
Old January 26th, 2007, 03:31 PM
hlamar's Avatar
hlamar
Heston LaMar
97 NAS D90 ST #1789
Okay, mechanic has a theory on what happened -- he said many of my seals are dried and cracked. He said they were likely sealed up by sludge, so once the Sea Foam cleaned-up the sludge, out came the oil! See new post about related repair question please!
Heston
seals
Sea Foam kellymoe Defender Technical Discussions 100 January 17th, 2016 06:40 AM
advice on seals? hlamar Defender Technical Discussions 9 February 6th, 2007 12:44 AM
Front Vent Flap Seals Flagg Defender Technical Discussions 14 February 20th, 2006 05:14 PM
Replacing Vent Seals TND90 Defender Technical Discussions 3 January 14th, 2006 08:02 PM
OEM front seat covers and foam - used dmarchand For Sale - Parts 1 December 1st, 2004 09:30 AM
