Sea Foam - Page 4 - Defender Source
Old May 19th, 2011, 10:26 AM
Originally Posted by grnthng View Post
Sorry, forgot to click on upload! Here we go.... ooooo, aaahhhh!
Thank you for making my day. That was "post-worthy".
On a side note, for TDI folks, I've learned alot about turbo and turbo health over last 6 months. Many turbo shops recommend not using additives in the oil as loosening particles is bad for turbos. Small particles that break free can clog the turbo oil inlet (very small port) and kill the turbo in short time.
That's also why they all recommend replacing the oil feed line, rather than cleaning it, when replacing a turbo. risk of particles is too great.
Not my advice, debate it all you want.
Old May 19th, 2011, 10:47 AM
achampagne's Avatar
achampagne
Adrian Champagne
06 LR3 HSE
I'm changing the oil in my disco this weekend , I think I'll buy a bottle and give it a try.
Old May 19th, 2011, 05:49 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Thumbs up
Put in two, it should be twice as effective.
Old May 22nd, 2011, 12:36 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
just seafoamed the 90 and wifey's 30K VW GTI. Honestly didn't see much smoke with the 90 (changed fuel filter and filled new one with seafoam and a bit of ATF) but the petrol GTI... WHOA. Going for a drive now to see if it feels any different.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old May 24th, 2011, 06:00 AM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Originally Posted by tjfslaughter View Post
A combination of metamucil, seafoam and babywipes will fix this.
This was hilarious.
Just wanted to say I've heard nothing but bad things about Seafoam and it's counterparts.
Old November 28th, 2011, 09:35 AM
I picked up a gallon of the Seafoam / Sea Foam stuff over the weekend for my truck, and some 2 cycle engines.
Here's the video of start-up of the truck after sucking in about 6 ounces of the Seafoam through the vacuum on the brake master, and letting it sit about 12 minutes. You can see my nice exhaust leak ala muffler hole under the truck. Yes, I did this at an old abandoned Verizon lot, as you don't want an unnecessary call made to the Fire Dept!
ID:	44203   Click image for larger version
Old November 28th, 2011, 10:01 AM
any noticeable changes in the trucks behavior. I have always been on the fence about seafoam and have never used it. I will use techron prior to an oil change.
Old November 28th, 2011, 12:08 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Thats not too bad Josh. Mine smoked like hell for about 30 minutes.
Old November 28th, 2011, 12:27 PM
Nothing great yet, but I've also read it'll drive like crap for a bit after applying the treatment. I usually idle around 6-800 RPMs, and after the treatment I was idling around 4-600 which is a little too low. Because of the intermittent lower idle I was getting the flickering oil pressure light, and then a Check Engine light after about 20 minutes of driving. I'll know more next weekend when I'm back at the car, and will report back with any continued issues after the application. Before the treatment I was already aware of the muffler hole (hopefully being replaced under warranty) and cats that need to be replaced once I get my new muffler, so some symptoms may be assoicated with that issue.
Old November 28th, 2011, 12:42 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Seafoam can foul up the plugs and/or O2 Sensors as well. I've run it through my truck on a couple different occasions with out problem.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old November 28th, 2011, 05:21 PM
bjf's Avatar
bjf
barry f
94 ST #395
What cats are you getting?
Old November 28th, 2011, 05:45 PM
I forget. I think Magnaflow 9914 or 9919 or something like that.
Old November 28th, 2011, 06:45 PM
bjf's Avatar
bjf
barry f
94 ST #395
Is that with a y pipe or are you cutting?
Old November 28th, 2011, 07:23 PM
Was thinking about this too, since there's free shipping and I have a $100 gift certificate.
http://www.roverparts.com/Parts/ESR3063.cfm
Old November 28th, 2011, 07:30 PM
bjf's Avatar
bjf
barry f
94 ST #395
When I did mine, I just had the old cut out but if I did it again I would either go NRP or would get a shop to make me something with random cats like ECR uses
Old November 28th, 2011, 08:24 PM
Do they test your trucks for emissions?
I have generally heard good things about using sea foam. I wouldn't think a vehicle that uses quality fuel sees high revs and regular maintenance would need sea foam
Old January 9th, 2012, 12:48 AM
323jamie's Avatar
323jamie
jamie
83 D110 RHD 300tdi Disco conversion
wondering
Old January 9th, 2012, 07:54 AM
Originally Posted by 323jamie
wondering
Wondering what.
Well, my truck is driving like a dream, but it's more likely because of the whole new exhaust system I had installed with new cats, and o2's, as one of the cats was bad.
Old January 9th, 2012, 08:41 AM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
Trailhead 4X4 made a SS Y-pipe with random cats for me. I think random is what ECR uses.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old January 9th, 2012, 08:52 AM
FYI, the only thing stainless on the NRP y pipe is the tailpiece. This is welded to a mild steel connector flange. Quite disappointed with mine. 'sides their warranty is for schmidt. stay away.
D90 Seat foam Capt Milks For Sale - Parts 0 February 13th, 2008 07:59 AM
the cushioning foam under the diamond plate cdb Defender Technical Discussions 12 December 8th, 2007 03:13 PM
Sea Foam burnt up seals? hlamar Defender Technical Discussions 7 January 26th, 2007 03:31 PM
defender seat cushion foam for sale draaronr For Sale - Parts 14 May 17th, 2005 12:09 PM
OEM front seat covers and foam - used dmarchand For Sale - Parts 1 December 1st, 2004 09:30 AM
