SD cage tech - Defender Source
Old January 24th, 2015, 04:16 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
SD cage tech
If you have a 2-door non-Tithonous soft top 110 with a SD roll cage (particularly the RBL0987SSS), I need your help: I need some detailed pics of your cage for a project I'm working on. Specifically, I need some pics of the front cage hoop: how it mates with the drain channels and how it mates with the tub. I've scoured the 'net Horsey-style but I can't find anything besides the two crappy photos from SD's page.
So I'm planning on ditching my Kid N' Play high-rise Tithonus roll cage for a standard SD cage that can accommodate a standard Exmoor canvas soft top. There are two potential contenders:
RBL0987SSS - A cage that's been made by SD for a while now. It supposedly sits aft of the front hoop (the galvanized, stocker LR soft top one) and relies upon that front hoop to support the drain channels.
RBL2447SSS - If you subscribe to the SD mailing list, you probably read about this one recently. It's their new cage that fully replaces the front stock hoop and ties in with the drain channel directly:
The easy solution is for me to ditch the Tithonus cage completely and install one of those SD cages. The difficult but more desirable solution is to figure out how to retain the sturdy windshield roll cage that came with Tithonus and tie it into one of these SD cages.
For those unfamiliar, the front section of the Tithonus cage has a tube that runs above the doors and stops abruptly. A large bolt goes through this tube and mates with a tab that sticks out about 3-4" forward of the B-pillar hoop. To mate this front cage with one of the shorty SD cages, I could either modify the drain channel bracket on the B-pillar to accept the big bolt or I could cut the horizontal tube somewhere above the door and sleeve it to an extended tube that comes back to meet with the roll cage, a la the NAS-style cage.
Before I decide, I need some pics of the 0987 cage. Anybody run one of these?
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old January 24th, 2015, 11:10 AM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Do these pictures show what you need for the drain channel?
ID:	111889   Click image for larger version
Old January 24th, 2015, 11:43 AM
chris snell
Chris Snell
87 Ex-MOD 110
That looks like the newer hoop-less cage, the 2477, right?
2013 LR4
Old January 24th, 2015, 11:55 AM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Yes, it's the newer cage. Those photos are on the SD website. Seems like if you want to keep the Tithonus front hoop the bars above the doors will need to be shortened since the Tithonus b hoop mounts further back on the tub. Seems like the vertical location would be very close to where the drain channel mounts to the b hoop on the 2447 cage tho.
Old January 24th, 2015, 12:01 PM
chris snell
Chris Snell
87 Ex-MOD 110
Yeah, that's along the lines of what I'm thinking. I will probably cut Her Majesty's Own horizontal bars somewhere above the door and sleeve them onto a piece that comes back to meet the SD cage like the NAS trucks do.
2013 LR4
Bill Larson's Avatar
Bill Larson
Bill Larson
Do you realize these trucks are rare and you are defiling its soul by by bastardizing it away from what the factory, MOD, and Queen intended?
-Jeff
I think LR, the Ministry and the Queen have done their fair share of bastardizing to look the other way!
cage
OIL Cooler lines TECH page steved90 Defender Technical Discussions 25 May 11th, 2006 10:13 PM
POE hardtop "tech" evilfij Defender Technical Discussions 3 July 12th, 2005 12:41 PM
Odd intake compatibility question for Rover Tech types Hans Defender Technical Discussions 3 December 13th, 2004 07:39 PM
Closing a thread + tech articles paulb Support & Suggestions 4 November 2nd, 2004 01:36 PM
» Defender Registry
Boomer
bsjbrown
Toby
Willh
Add your Defender
