SD Cage Bolt Size? - Defender Source
Old November 21st, 2012, 08:25 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
SD Cage Bolt Size?
I'm away from my truck....
Anyone know off hand what size bolt the NAS 110 SD cage uses? Looking for the primary hex head bolt used on the exterior portions of the cage. M12?
Semper Fi!
Old November 21st, 2012, 08:29 AM
The bolts are Torx T-50 heads M10 -1.50 x 3.175
Old November 21st, 2012, 08:36 AM
Wolf Fabrication
Sterling Archer
'08 D3
Those are the body mount bolts. Looking for the bolts that bolt the cage together - hex head.
Semper Fi!
Old November 21st, 2012, 08:46 AM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
M10 30mm 1.5 pitch
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old November 21st, 2012, 08:54 AM
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by Reese_D90 View Post
M10 30mm 1.5 pitch
You Sir, are a gentleman. Cheers!
Semper Fi!
cage
Steering pump adj bolt size? DaveHuny Defender Technical Discussions 2 September 3rd, 2005 01:44 PM
Bolt size for Diff? UpnOver Defender Technical Discussions 3 July 5th, 2005 08:28 AM
TC cover plate bolt size? dmarchand Defender Technical Discussions 1 December 24th, 2004 06:59 PM
bolt size for bonnet hinge Campbell Defender Technical Discussions 1 November 7th, 2003 10:41 AM
