Screw size for fan shroud - Defender Source
Old April 19th, 2010, 09:51 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Anyone know what size those 4 tiny screws that hold the fan shroud in place are? They have that weird unthreaded tip then the threads start half way up. I need 4. who sells them?
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old April 19th, 2010, 11:17 PM
bd90
94 Arles Blue #1644
No kidding. What's up with that. I recently removed the shroud and went to replace screws and they don't screw in all the way or something. It's like there's a spacer that should be in there that's missing. Try George at RDS. I bet he's got them.
Old April 19th, 2010, 11:34 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
http://www.roversnorth.com/store/p-1...an-shroud.aspx
http://www.roversnorth.com/store/p-2509-screw.aspx
Old December 6th, 2014, 01:12 PM
Bump - I need a set ... actually fit the very shroud that Daniel was installing in this thread ... which I now own.
The RN links don't work anymore so any help appreciated.
Old December 6th, 2014, 01:36 PM
Screw is - 562979
spring washer is - VYF500110
Old December 6th, 2014, 01:38 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
These?…. http://www.roversnorth.com/ProductDesc.aspx?code=562979
And anyone know if they work on a RRC? Getting tired of the zip ties.
Old December 6th, 2014, 01:40 PM
they look like this http://www.brit-car.co.uk/search.php?xSearch=562979
Old December 6th, 2014, 01:56 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
$1.59 for a screw plus shipping?
I think you can find an alternative...
Rent my
Old December 6th, 2014, 02:05 PM
$1.59 for a screw plus shipping? I think you can find an alternative... .
Totally worth the price. They are unique. Better than hacking something together that comes off or holes the rad. I bought packs and sent out spares years ago.
Old December 6th, 2014, 02:20 PM
Call Trevor. http://www.rovahfarm.com/ 69˘, so $2.76 for all four. -Jeff
Man I want the 1% version ..
http://shop.urbanlandcruisers.com/sh...cowl-562979-4/
Old December 6th, 2014, 02:32 PM
I don't think you can put holes through the radiator by using the wrong screw, the core is recessed further forward than the screw hole.
Old December 6th, 2014, 06:55 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
None of my Rovers have ever had those screws...this is the first time I've seen 'em.
Jimmy's correct...you'd have to use a pretty long screw to do damage.
Leave the 1" drywall screws in the drawer.
Rent my
Old December 6th, 2014, 07:08 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Trevor is out of these and they are on back order.
[DQUOTE=JSBriggs;587619]Call Trevor.
-Jeff[/QUOTE]
fan
Vent cover screw size Buckon37s Defender Technical Discussions 10 April 25th, 2007 05:34 PM
I'm making a custom fiberglass electric fan shroud for D90, anyone interesed? jaherring Defender Technical Discussions 1 November 22nd, 2005 01:06 PM
What size socket? kit Defender Technical Discussions 1 February 7th, 2004 02:26 AM
