Screw Loose - Mental Health and owning a Defender - Defender Source
Old July 7th, 2014, 11:13 AM
richord
Richard Ordowich
1987/D90
I think that medical health insurance should have a provision for Defender owners. From my experience Defender owners suffer from the "screw loose" syndrome.
In the limited time I have owned my Defender I have found numerous instances of loose screws. Loose window crank assemblies, lose read door latches, loose hood etc. Most recently the header screws on my engine. This discovery was by accident.
I dropped a screw on the top of the engine while trying to repair the shroud around the turbo charger. As I was searching for the screw, I came upon a loose nut (not me) which was one of the fasteners that hold the header to the block. I checked the other bolts and found two others loose as well.
The good news is that most screws and bolts will not fall off. They are prevented from falling off by nature, rust. After this most recent experience I went about checking to see if I had other screws loose.
What is required is a physician's (mechanics) guide to loose screws. A map of all the accessible bolts and screws and a treatment plan to check each and every one. By the time you check all the screws it will be time to start over. This of course could lead to the need for life long "screw loose" treatments.
Old July 7th, 2014, 11:16 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
You didn't mention the loose nut behind the steering wheel!
Old July 7th, 2014, 11:26 AM
richord
Richard Ordowich
1987/D90
The the loose nut behind the wheel only happens when I don't tighten the steering wheel nut. I always keep a pair of vice grips handy when that happens.
Old July 7th, 2014, 12:46 PM
A full set of m4,m5,m6,m8,and m10 nylocks really helps
Old July 7th, 2014, 12:51 PM
When working on my wife's Volvo, noticed that the engine mount off the suspension tower brace looked odd. The Engine had been pulled to fix the tranny about 70,000 earlier. We found the original bolt lodged in the engine bay......
Does that mean Volvo mechanics are nuts?
Ok tell me I'm not mental o2batsea Series Technical Discussions 3 October 10th, 2011 11:47 PM
Funny things you've heard while owning a Defender James Pierce Misc. Chit-Chat 15 August 8th, 2011 11:32 PM
The joy of owning a old defender... mongosd2 Misc. Chit-Chat 7 December 17th, 2010 01:59 PM
the joys of owning a D-90 isleofman Misc. Chit-Chat 6 September 24th, 2008 01:54 PM
Green d90 softtop @ sport and health bethesda SpicoliWouldGo Misc. Chit-Chat 5 September 22nd, 2005 09:39 PM
