Scraping noise when I turn left - Defender Source
Old July 30th, 2014, 12:52 PM
bjf's Avatar
bjf
barry f
94 ST #395
Sometimes when I turn left I hear a scraping noise like a brake is dragging.
Thoughts?
Old July 30th, 2014, 12:54 PM
Maybe a brake is dragging.
Thoughts?
Old July 30th, 2014, 12:56 PM
bjf's Avatar
bjf
barry f
94 ST #395
Will check it out. Parking brake is kinda screwed up.
Old July 30th, 2014, 12:58 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Sounds like Half Shirt needs to pay a visit.
Old July 30th, 2014, 01:00 PM
bjf's Avatar
bjf
barry f
94 ST #395
He's too busy posting on every single thread.
Old July 30th, 2014, 01:04 PM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
Check the dust shield when the wheels are turned. I had the same problem and couldn't see any dust shield contact when I turned the wheels and hopped out to look. You may have to get someone to crank the steering all the way to the left while you are looking at the wheel.
Old July 30th, 2014, 01:34 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
also ensure your bolts for the caliper are tight, if they are loose the caliper can move causing various wonderful sounds from the wheels/axle
Old July 30th, 2014, 02:08 PM
bjf's Avatar
bjf
barry f
94 ST #395
Will check it all out.
Old July 30th, 2014, 02:09 PM
Run over any cyclists recently?
Oil light flickers during left turn cellulararrest Defender Technical Discussions 11 July 7th, 2013 03:49 PM
Wanted 1994 D90 Left Front Turn Signal Lamp Assembly kylexh Wanted 4 February 15th, 2010 01:56 PM
Left turn signal Defender13 Defender Technical Discussions 7 February 22nd, 2007 08:24 PM
Turn right noise ... Fatman Defender Technical Discussions 2 December 10th, 2004 09:54 AM
wind noise with fiberglass top GliderKing Defender Technical Discussions 4 October 10th, 2003 04:13 PM
